Home > General > OEM v's spurious side steps.
grass cutter
Hi everyone, first post for me.
I bought an 08 TDV8 in november without side steps when i thought i didn't like them but have since changed my mind.
Personal finances are going to be very tight for the next year or so and i can't justify the expense of the OEM items.
My question is what are peoples experiences/opinions of fitting non genuine steps ?
Many thanks, mike.
Post #369696 Wed Jan 16 2013 11:24pm
Big ken
Scotland 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Ebay Thumbs Up
Perfect fit Thumbs Up 2.7 TDV6
22" Stormer alloys
Side steps
PS3
Headrest monitors
Black badges
Stainless tailpipes
Privacy glass
L.E.D. lights throughout.
Post #369719 Thu Jan 17 2013 7:44am
Peanut
Got mine from -
http://www.lrparts.net/scp/2010_RANGE_ROVE...=VTK500020
Very pleased with them and the price. Current: MY15 RRS2 3.0 SDV6 Autobiography Dynamic, Aruba Gold, HUD, Meridian 1700w
Gone: RRS TDV6 2007 Stornaway
Gone: P38 2.5 DHSE
Post #369720 Thu Jan 17 2013 7:54am
PEACHY
I was in the same situation - opted for the cheaper lookalikes - never had a problem - fitted within a couple of hours .If you can afford a little extra I would opt for the versions that come with the PRE CUT sill replacements a little less hassle than cutting your own. Thumbs Up 16MY Estoril Blue SVR.............
Post #369721 Thu Jan 17 2013 9:08am
When you have fitted them make sure you give the aluminium trim a few coats of a good wax, this will stop them from tarnishing. Thumbs Up
Post #369725 Thu Jan 17 2013 9:21am
Peanut wrote:
http://www.lrparts.net/scp/2010_RANGE_ROVER_SPORT/products.asp?partno=VTK500020
That's strong money Whistle Laughing , try here
£149 delivered......but you can make an offer too Thumbs Up
Edit: I have no link to this advert Smile ON THE WAY: BMW F21 M140i
Post #369728 Thu Jan 17 2013 10:27am
imb111
2010 Range Rover Sport TDV8 HSE Java Black
looking to get the ebay ones aswell, heards lots of good feedback Thumbs Up
Post #369774 Thu Jan 17 2013 3:54pm
cmcb
Scotland 2008 Range Rover Sport TDV8 HST Stornoway Grey
I got mine from eBay and try are spot on. If you can get a set with pre cut sills as it will save a bit of faffing and effort. They are pretty straight forward to fit too RRS TDV8 HST
BMW 330Cd M Sport
Post #369877 Thu Jan 17 2013 11:40pm
grass cutter
Well thanks for making my mind up for me everyone, gonna get the cheapies and wax the ally trim.
All the best, mike.
Post #369881 Fri Jan 18 2013 12:01am
sparky8181
When I purchased my sport it came with OEM steps and they were a bit scruffy so I ordered the eBay replicas to replace them, the eBay ones were exactly the same and I didn't even have to change the brackets as they were identical to the OEM ones so the new steps just slid on, took about half an hour and you would never tell they weren't the original ones Very Happy
Post #369884 Fri Jan 18 2013 12:13am
sparky8181
+1 for going to apply wax to them, thanks for the tip Ady Thumbs Up
Post #369885 Fri Jan 18 2013 12:15am
BKHK
I know that money is always a sensitive subject (so is everything on here it seems) but am I alone in seeing something strange in being able to afford to buy a RANGE ROVER, then spoiling the originality by buying cheap (many Chinese made) side steps? If the car itself represents so much disposable income that to buy some side steps means cheap facsimile parts, isn't it better to get a cheaper car? To me, a Range Rover would always be worth OEM parts. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #369891 Fri Jan 18 2013 3:47am
A similar thought went through my mind BKHK. These things aren't cheap to run at the best of times so trying to do it "on the cheap" seems a little silly. But some people manage it and good luck to them.
The funniest bit in the thread is the bit about waxing them to keep them shiny. Mine are a bit scratched and dented from being used as makeshift rock sliders - should I wax them too? Rolling with laughter
I'm still trying to work out what a "spurious side step" is too... Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #369901 Fri Jan 18 2013 9:19am
The wax isn't to keep them shiney, infact the aluminium trim isn't shiney at all Embarassed The wax helps protect the aluminium trim from getting tarnished as said in my previous post. Whistle Unprotected aluminium will tarnished and corrode. Its also worth protecting the aluminium rivites that hold the trims on, these have been known to corrode and cause the trim to fall off.
Post #369903 Fri Jan 18 2013 9:26am
Ady, just pulling your leg Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #369911 Fri Jan 18 2013 10:16am
