![]() | Home > Technical > do tdv6 range rover sports use oil ? |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
How many miles has it done since it was last serviced? 2014 L405 SDV8 RR Autobiography |
cozzyrick Member Since: 03 Nov 2012 Location: staffordshire Posts: 17 ![]() ![]() |
I would say around 1200 ish miles 2008 range rover sport FANTOM styling
pedro444 Member Since: 20 Jul 2012 Location: Warwickshire Posts: 8 ![]() ![]() ![]() |
TDV6s with DPFs actually tend to gain oil between services. It's not actually oil but fuel that has found its way to the sump - the regen process injects a bit of extra fuel to get the DPF temperature up (well that's how it works on my Jag XJ and it's the same basic engine - our RRS TDV6 is an early one without a DPF). As a result and to prevent problems with oil levels getting too high between services the engine should be filled only to between min and midway.
no its been around 3 months from when it was serviced and I never checked it then as you would of thought it would be bang on coming out of the main dealers. I will keep my eye on it now 2008 range rover sport FANTOM styling
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
Not sure the 2008 RRS had DPF fitted. Mine doesn't. 2012 SDV6 - it's missing a couple of cylinders
All engines can be expected to use some oil yes. Oil and any reservoir should never be overfilled, but should always be close or at maximum levels, not only does this allow you to use oil without running dry, but operating at certain angles requires a good res balance.
thanks mse 2008 range rover sport FANTOM styling
What you need to keep an eye on is excessive use or sudden drops Mike
I would have said a litre in 3 months is quite high?..especially as you've only done 1200 miles....
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 ![]() |
I've had my 3.0TDV6 for just over 3 months now, it was serviced before delivery, and I've covered about 1600 miles since then.
yes I will be checking it weekly now for sure and hope every things ok with it 2008 range rover sport FANTOM styling
