Home > Maintenance & Modifications > L.E.D DAYTIME RUNNING LIGHTS
JEDS_SDV6
United Kingdom 2012 Range Rover Sport SDV6 HSE Luxury Alaska White
Hi im new to this site i have been told by a good friend that you can have your l.e.d day time running lights turned on 24/7 without doing them your self is there anyone that can do it for me ? Thumbs Up [/b][/i] J.DAVIES
Post #368605 Mon Jan 07 2013 6:33pm
StevoD
Re: L.E.D DAYTIME RUNNING LIGHTS
Hi there JEDS_SDV6, welcome to the forum, I think you'll find it of interest, as a new member I certainly have.
Anyway, you're asking a question that I asked when I joined (must be a common thought) and if you have a look at this thread you'll see that it's pretty much been discussed to death.......with polarised views on the topic !!!
http://www.rrsport.co.uk/forum/topic27810.html?highlight=drl
If I'm in any way wrong I'm sure somebody will steer you in the right direction.
Regards MY12 RRS SDV6 HSE
Santorini Black with piano black wood and truffle leather
Hawke tips and all black grill
Privacy glass
Gone: too many to mention !!
Post #368607 Mon Jan 07 2013 7:04pm
The current model RRS doesn't have DRL's, they are called LED signature lights, your dealer can set them to come on when the ignition is switched on but your rear lights will also be on, there isn't and option to have just your front LED lights on. Whistle This will change on the 2014 RRS. Thumbs Up But as posted above in the link you can have them fitted.
See below
P/s welcome to the site. Wink
Post #368608 Mon Jan 07 2013 7:06pm
I wonder if it might be possible to make the front sidelights come on whenever the ignition is on irrespective of the light switch's position i.e. run a constant live to them. If one could, and one fitted a suitable LED bulb then a DRL effect would be achieved without having to run the rear lights too. 2012 SDV6 - it's missing a couple of cylinders
Post #368697 Tue Jan 08 2013 8:54pm
I'd be intrested to know if the front bulbs in the LED signature lights can be upgraded to brighter bulbs ie Audi/volvo brightness Wink
Post #368702 Tue Jan 08 2013 9:28pm
