Home > General > New supercharged owner with a thermostat question |
http://www.rrsport.co.uk/gallery/albums/us...mostat.pdf Malaysia Boleh!
Mon Jan 07 2013 12:39pm |
jitzz Member Since: 10 Dec 2012 Location: Loughborough Posts: 26 |
Thanks alot for the link Bobby !!.....much appreciated.
Mon Jan 07 2013 2:34pm |
No bleeding required... Malaysia Boleh!
Mon Jan 07 2013 2:43pm |
Thanks Bobby....
Mon Jan 07 2013 6:05pm |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
oi Bobby long time no see happy new year to you
Tue Jan 08 2013 1:02pm |
Hi Angel.. yes, I do drop in from time to time... and Happy New Year to you too!!
Wed Jan 09 2013 11:47am |
i will wait until the end of the year for a second hand L405 SC
Thu Jan 10 2013 1:38pm |
Thanks Bobby ...the replacement thermostat is now in and working a treat ?!?!?..the temp goes to the middle and stays there too - which is a good sign.
Wed Jan 16 2013 11:18am |
Malaysia Boleh!
Wed Jan 16 2013 12:42pm |
acowx Member Since: 21 Jun 2009 Location: New Freedom Posts: 61 |
Hi there, How long did it take you to change it ? Did you need a bench vice to get the old stat out of the housing ? Thanks! |
Sat Jan 26 2013 4:15am |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
If your mpg is affected id have a look at the coolant temp sensor as these can fail and make the car over fuel. Certainly a common issue on VWs but I imagine same principle applies. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section
Sat Jan 26 2013 12:10pm |
Bobby, just checking that this applies to a RRS SC 2006 please ? Mine has a large plastic (air intake?) behind the fan cowling which isn't mentioned on the DIY ? |
Wed Feb 13 2013 8:32pm |
Hi There,
Wed Feb 13 2013 9:38pm |
