![]() | Home > Maintenance & Modifications > Brembo Brake Conversion |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
The rears are also larger, approx 20-25mm in diameter |
jdgeary1 Member Since: 11 Dec 2012 Location: Berkshire Posts: 41 ![]() ![]() |
Ah ok, so front and rears are normally brembos, no problem. Was going to do the fronts but will wait till I find a complete set. |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 ![]() ![]() |
Are standard s/c rears brembos?
You don't have to upgrade the whole lot at once, you can do one axle at a time. I will add a safety warning though, I would upgrade the fronts first, before the rears. It probably wouldnt make much difference to the stability of the car under heavy braking, but there will be more braking effort on the back end, which may be mismatched to the braking effort of the standard fronts. Worst case, it could make the back end unstable under heavy braking... Mitch, yes ![]() Straight swap ![]() |
