![]() | Home > Technical > Amber park brake light |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 ![]() ![]() ![]() |
Anyone |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4475 ![]() ![]() ![]() |
It means there is a fault in the system |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
Presumably a fault code will have been stored. I read somewhere the list of fault codes and a huge number of them just seem to be for spurious voltage readings (either signal voltage too high or too low). It could just be one of those caused by momentary glitch in the system. 2012 SDV6 - it's missing a couple of cylinders
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
As modern cars get more complex warning lights that reset after you restart the engine appear to be common |
Amber light are for minor issues to be checked. Car can be driven with care
Stefan.lajszczuk Member Since: 10 Oct 2012 Location: West Yorkshire Posts: 70 ![]() ![]() ![]() |
When you applied the electronic brake, did it squeal for about 5 seconds or so?
