Home > Maintenance & Modifications > Advice Please
panpicker
Advice Please
Just got my tdv8 sport back from a service, on the way home could not go as faster than 50mph and the car sounded like is was missing and dash reads engine fault !! After speaking to the garage was told air in fuel system as they changed the fuel
filter ? and if i turn the car off and then re-start let it run it will clear its self is this correct ????
Post #365788 Fri Dec 07 2012 7:45pm
P7tey
That doesn't sound right to me! Shocked
How far did you get before it started doing that?
Post #365799 Fri Dec 07 2012 9:22pm
panpicker
about 10 miles
Post #365802 Fri Dec 07 2012 9:39pm
Kimmea
Scotland 2013 Range Rover Sport SDV6 HSE Fuji White
Shocked that don't sound right.... What happens when you open your fuel cap and expose the fuel to air prior to filling up..?
Post #365804 Fri Dec 07 2012 10:27pm
Disco_Mikey
Split turbo hose, possibly. Quite common on TDV8's.
Good news is its an easy, and cheap fix Thumbs Up
Post #365805 Fri Dec 07 2012 10:32pm
panpicker
turbo pipes all Ok !! but all is well then for no reason the car reads Engine Fault and has now power, if i park up go back to the car start it up and again it runs ok with no fault, its had new battery & alternator, the garage have plugged it in and no fault found. But as usual the car is fine when at the garage which drives me mad. Great car but will send me to a early grave.
Post #366937 Mon Dec 17 2012 10:07pm
Bob.
Is that the top two at about £60/pair?
Post #367160 Wed Dec 19 2012 11:16pm
B.Safe
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
1: Turbo pipe is not properly fitted, maybe the tiding collar is untied
2: or a sensor from the engine is gone and costs about £700
Big Cry
Let me know if I was right
Big Cry /|\
Post #367169 Thu Dec 20 2012 2:14am
Disco_Mikey
Yes Thumbs Up
Post #367174 Thu Dec 20 2012 8:02am
panpicker
Problem solved !!!! sticking Actuator common fault i've been told. The car has never run so well. thanks for all your replies.
Post #367410 Sat Dec 22 2012 10:02am
shakeapaw
Yes Thumbs Up
give over, £11.08 each from an indie, genuine LR parts as well, ive just had mine done 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #367460 Sat Dec 22 2012 10:49pm
Disco_Mikey
They have come down in price in the last few months then Thumbs Up
Post #367465 Sat Dec 22 2012 11:10pm
shakeapaw
To be fair, he did quote me £18 at first, but when it turned up, that was how much LR had billed him, plus the VAT 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #367467 Sun Dec 23 2012 12:07am
