![]() | Home > Technical > Egr Valve |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 ![]() ![]() ![]() |
Hi all can anyone explain what symtoms you get with a sticking egr valve on a 55 plate sport diesel i assume there is only one and is it possible to lubricate them /it if so how do i find it/them thanks in advance pete
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
Lack of power, poor throttle response etc
Thanks Mikey for your help my rrs is fine i just keep reading and hearing about egr valves and im new to rrs so just getting a little knowledge probably wont sink in but worth a try cheers pete |
Personally, I would have them blanked off, regardless if there was an issue or not.
Hi mikey a daft question will blanking them off interfere with mot can you tell if it has already been done and lastly is it easy enough to do is there a how to on here thanks pete |
It wont interfere with the MOT as yet. It is still not a failable item.
So it's better to blank than remove so if it does become mot able you should be ok what is d3 iirc please |
Disco3.co.uk + If I Remember Correctly
Hi mikey if you or anyone could point me in the right direction of a how to for tblanking he egr valves on a rrs 55 plate i would be grateful im about to have the cambelt done so i might do it myself with the help of a mate and do the egr's while im at it just so i know they are blanked off thanks in advance |
Thanks mikey looks tricky anyone near to wigan who does this job let me know cheers pete |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 ![]() ![]() ![]() |
I've been thinking of blanking mine off, is it possible on an 07, I've read somewhere that it might not be, how can I tell for sure? Is it a chassis number thing? |
The 10th digit of the chassis number, corresponds to the model year of the car.
Blonde question - what does the MY stand for?
Model Year |
