Home > General > Channel tunnel ???? |
Will fit in the 'normal' car space ON THE WAY: BMW F21 M140i
Sun Nov 18 2012 10:00pm |
Coolbanana Member Since: 24 Oct 2012 Location: Buckinghamshire Posts: 38 |
Yep, no problems at all. I took my Discovery 4 over to France several times using the Tunnel in the normal car section and they are taller than a RRS. Current car: Porsche 911 Carrera S PDK (997.2) Past Car: (MY12) Range Rover Sport HSE SDV6 - Orkney Grey with Almond interior
Sun Nov 18 2012 10:20pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Cool it's a lot taller than my Evo lol |
Sun Nov 18 2012 10:41pm |
Cheney Jawa Member Since: 25 May 2012 Location: Birmingham Posts: 89 |
Took mine through the other week and it was fine, you just have to clench your buttocks when you drive under the height barrier thingy's!!!! Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack |
Mon Nov 19 2012 2:27pm |
Thank did you put the car in to access mode and limbo under |
Sun Nov 25 2012 5:15pm |
Heuerman Member Since: 23 Aug 2011 Location: Nottinghamshire Posts: 62 |
Go into the over height lane and you will end up in a carriage with no parapets to scrape your wheels, plenty of room to walk around and less queuing to get on. You also get to mix it with any Ferrari's, Lambo's , Porsche Turbos and other wide exoitic machinery. Only disadvantage is the toilets are at the front of the train where the coaches park so make sure you take a comfort break at the terminal. You will be off the train well before the other cars. '10 Range Rover Sport TDV8
Thu Nov 29 2012 5:42pm |
