Home > General > In and Out of Access mode
Dingoz
Australia 2005 Range Rover Sport 4.4 V8 S Bonatti Grey
Had my Sport for 6 weeks now and am loving it to death. Just have one question.
When I put it into or out of access height, the car jerks and lurches going up/down one corner at a time. If I select access height while still moving it is almost not noticable. I had figured that the slight camber change and friction between the road and tyres was the cause of the jerkyness, and while moving the suspension could "normalize" and hence the the jerkyness is reduced.
I think I have answered my own question, but it would be foolish not to ask the collective wisdom of this forum RRS '05 4.4 Bonatti Gray Black Leather
Discovery S1 3.9 manual with extractors
Mitsubishi Starion (ex group e production car)
Post #362467 Fri Nov 09 2012 1:53am
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Does'nt sound good to me Neutral
Post #362479 Fri Nov 09 2012 8:39am
If you lower the driver's window, put the park brake on and then reach through the window to change the suspension, you'll see that the front wheels roll forward or backward slightly depending on which way the suspension is moving. Suspension height changes the car's wheelbase dimension slightly. Do that with your foot on the brakes (locking all 4 wheels) and something has to give - hence the jerky feeling. Doing it on the move isn't an issue of course. 2012 SDV6 - it's missing a couple of cylinders
Post #362481 Fri Nov 09 2012 8:42am
You may find the compressor's just a little bit tired thus exaggerating the "jerkyness" while stationary. RRS gone
Post #362489 Fri Nov 09 2012 9:52am
