![]() | Home > Maintenance & Modifications > Replacing Struts |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
Hello
Hello
finbarfinnegan Member Since: 26 Aug 2011 Location: Banbridge Posts: 19 ![]() ![]() ![]() |
Hi shepp - any idea where? I'm being quote way over 300 plus VAT for genuine LR parts. The delphi units are about 210 and 220 plus vat.
http://britishparts.co.uk/t/range-rover/ra...suspension
Thanks Shepp - i found some good ones marked OEM on the Rimmer site too - stated as from same factory, just with diff packaging.
hello
Brilliant Shepp - i think I'll call them and give them my VIN just to make sure I get the right parts (can't decide if I have Ace or not)
do you have a manual?
Ace are the active cornering enhancement, are your anti roll bars fixed or are they adaptive, should show up which one on a vin search, or just look in your handbook |
I've not got a manual - any idea where to download one?
pm me your email, and i will get it tempararily hosted through a 3rd party so you can download it, as it is to large a file to email, won't be till later this evening as working till 6 then on call until the morning. |
It's definitely got the DSC 6 big button on the dash board for that one, and it seems looking at the parts that they either are for "with DSC & ACE" or without. No splitting of that - but I'll check to be sure.
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Look under the bonnet to see if you have Dynamic Response ie active anti roll bars or ACE. If the DR fluid reservoir is missing you don't have it.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
If you have a Britpart dealer local to you, they come boxed as OEM.
