Home > In Car Electronics > iPhone Bluetooth connection |
The module will remember up to 8 paired phones. But only one is active at any one time. It will re-pair with the last paired one if both of you get in the car at the same time.
Fri Oct 19 2012 7:59pm |
gwdalba Member Since: 03 Sep 2010 Location: Nairn Posts: 46 |
Thanks Bodsy that explains it. I don't have the phonebook feature on my 2006 HSE. RRS 3.0 SDV6 HSE 2012 Santorini Black
Fri Oct 19 2012 8:25pm |
Would you like it? It's a simple swap for you. Let me know by PM Bodsys Brake Bible
Fri Oct 19 2012 9:06pm |
AJS7 Member Since: 23 Oct 2012 Location: London Posts: 8 |
Hi Bodsy,
Tue Oct 23 2012 8:02pm |
You definately have the red and green buttons on the steering wheel? If so and it's the factory fit BT unit, then it needs a software update. Will reply to your other post on the options available to you. Bodsys Brake Bible
Tue Oct 23 2012 9:06pm |
Thank you, I will get back to you. |
Wed Oct 24 2012 7:26am |
