| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > permanently lowering my RR sport TDV6 2006. |
| Ste Sleds Member Since: 01 Dec 2007 Location: Barrow in Furness Cumbria Posts: 60    |
 Do you Not find the ride is terrible with it lowered, don't think I would like to travel far with it like that. | ||
|  Fri Oct 19 2012 10:41am |
| Rudskibaliblu Member Since: 05 Feb 2010 Location: Western lake district Posts: 329      | You can buy a plug in module that keeps it at s set  height, not sure think Awd mans got one fitted.  Sure he will be along soon to give you the details  | ||
|  Fri Oct 19 2012 11:12am |
| mlines Member Since: 10 Dec 2006 Location: UK Posts: 480    | http://www.gap-diagnostic.com/ then buy it from Britpart 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit | ||
|  Fri Oct 19 2012 11:56am |
| V88ABA Member Since: 01 May 2012 Location: northampton Posts: 338    | I'm selling one if you want one. Gap diagnostic. Plug in and play! Lowers by anything upto 30mm | ||
|  Fri Oct 19 2012 11:59am |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | As above   | ||
|  Fri Oct 19 2012 12:07pm |
| Franko Member Since: 21 Aug 2012 Location: Glasgow Posts: 13      |
 How much are you looking to get for it? And does the device still allow me to use the lowering and raise buttons to set heights? For example if I lowered it to 25m then how would I get it back to normal road height if I wanted to use it for a longer journey? And then do I need to plug in again to get back to my 25m or do I just use the button in the centre console? Apologies for the questions its my first RR venture. Thanks. Range Rover Sport Supercharged 2006 plate | ||
|  Fri Oct 19 2012 3:57pm |
| V88ABA Member Since: 01 May 2012 Location: northampton Posts: 338    | When it's plugged in you manually select hight by mm.
|  Fri Oct 19 2012 9:50pm |
 Ok I get you! Sounds easy. Is there any negatives with it? Or faults that may occur by doing this? And how much are you looking for? Thank Range Rover Sport Supercharged 2006 plate | ||
|  Sat Oct 20 2012 8:51am |
| Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852      |
 Franko, I've been running the EAS/IID Tool lowered suspension (-15mm) now for quite sometime and have had no fault codes etc occur. However, I will say going from standard height with 285/50R20 tires to -15mm ride height and 285/35R22 I have noticed the ride firm up significantly, however, I have to say it's not offensive, even on the poor roads we have here. Regards Guy 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" | ||
|  Sat Oct 20 2012 12:38pm |
| kml4ever Member Since: 23 Dec 2011 Location: İstanbul Posts: 35      | Lowermyairride is the best i had it and works great but as awdman says you loose the acces height but it worth for it and very cheap KML4EVER | ||
|  Sat Oct 20 2012 9:03pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Just don't forget to get your wheels re-aligned or you'll be scrubbing off a new set of tyres in next to no time. Bodsys Brake Bible
|  Sat Oct 20 2012 10:21pm |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | In addition, the EASControl unit takes a backup of the vehicles standard ride height settings prior to any adjustment by you.
|  Mon Oct 22 2012 8:01am |
| saimans Member Since: 22 Oct 2012 Location: UK Posts: 46    | I had the adjustable links from lowermyairride it did what it was supposed to do. I set it to the lowest and OMG what a stupidly hard ride. It looked fab, but was totally undriveable even a leaf in the road had you quaking. I got rid of them in the end as it messes about with the ride height settings too much and was a PITA. | ||
|  Mon Oct 22 2012 2:56pm |
| Stryke Member Since: 16 Nov 2010 Location: UK Posts: 99      | Recently bought the IIDTool and lowered my FFRR. No faults, car looks a lot nicer now, especially with the 22" wheels.
|  Mon Oct 22 2012 5:48pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
