Home > Technical > Key Fob Battery?
P7tey
Key Fob Battery?
Hi,
I've picked my 2005 RRS yesterday and it's great. However, the spare key remote doesn't work / won't charge. I'm sure I read a thread on here about a cheap fix for this and avoiding a trip to the dealer, but I've searched and can't find it.
Is there an other option apart from getting a new key and reprogram? (Or trying to solder a new battery in myself, which I'd probably cock up...)
Cheers,
Pete
Post #359563 Sat Oct 13 2012 10:22pm
Montythegod
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
I replaced the battery in my spare fob, hardest bit was spliting the key open... Battery is a rechargeable cell thats soldered onto the pcb, and wasnt too hard to change.. If you have a soldering iron and a desolder toolcgive it a go ! 5 quid for the battery and some superglue to put it back together Cool Why?.. Because i can....
RRS 2006 S/C Rimini Red Weekend toy
Subaru impreza 1998 2.0 340hp still here
Smart car 0.7 61 hp Carbon offset
Sierra cosworth 2.0 350 hp GONE
Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's....
Mr Mischief - www.mischief-inc.co.uk Wink
Post #359564 Sat Oct 13 2012 10:36pm
P7tey
Thanks for the advice, you're right, i ought to give it a go, (or get someone I know to anyway!).
Cheers for the heads up!
Post #359565 Sat Oct 13 2012 10:50pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
What doesn't work? Willmitnstart the car, if so you need to leave it in the ignition for around 7mns for it to re sync with the car, will take a while to charge I would have thought. If you took some fog and put it in a jar, would it be missed.
Post #359595 Sun Oct 14 2012 1:15pm
Montythegod
the battery in mine wouldn't take a charge as it hadnt been used for so long the battery had failed Sad it started the car ok but wouldnt lock unlock remotely until the battery is changed... I now alternate the keys to ensure a consistant charge Why?.. Because i can....
Post #359626 Sun Oct 14 2012 5:00pm
P7tey
My key will start the car. I have been using it to try and get it to charge but no joy. I may have a go at replacing the battery to try and avoid having to buy a new key!
Post #359629 Sun Oct 14 2012 6:46pm
Lateral5
Australia
Followed the battery replacement thread on D3 site and saved $900 on two new keys.
Bought:
2 casings on ebay at $50,
2 batteries at $24
1 soldering iron at $14
All up $88 for two fixed keys (hardest part is opening the old ones).
Dealer quoted $395 for blank, $66 for pairing + unknown for key cut = min $461 per key.
Interestingly, when I opened one of the keys that wasn't working and just used the PCB, it worked again! I suspect there is a solder fault on the battery terminal anyway - thought I'd replace battery while I'm at it! Thumbs Up RRS TDV6 Bluetooth, VR, Roof
Post #376562 Wed Mar 13 2013 5:05am
Paul Holywood
what is the process for re programming a key for all three button to work?
Edited:
Decided to get a new one ordered from MD just in case.
Post #416362 Mon Mar 03 2014 7:36pm
Comeinhandy
Need to replace the rechargeable battery in keyfob
Changing the rechargeable battery usually fixes a non working key fob, just done the one on the wife's freelander2 which is very similar, so the method is the same, see my video of doing it in the link below, or if that doesn't work try searching on Google or youtube for "comeinhandynow"
Post #441563 Wed Nov 05 2014 12:50pm
