![]() | Home > Maintenance & Modifications > gearbox oil change |
I was warnewd not to use anything other than LR approved ZF Lifeguard
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
Are nt these gear boxes sealed for life? |
100k service I think. RRS gone
Mike767 Member Since: 31 Aug 2012 Location: Cheshire Posts: 19 ![]() ![]() ![]() |
There is a load of information on this subject over on the D3 site. Supposedly sealed for life, but lots of reports of gearbox shudder under load. I assume the same box is fitted to the RRS 2.7, but I'm a new RRS owner.
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
hi I changed mine myself
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
Gearbox oil is recommended at 150k/10 years, but well worthwhile replacing at 75k. Also consider erplacing the sump/filter assy at the same time.
LR are always a good source of duff information " .....I was told from LR was good as a lot of oil stays in transfer box ". |
The old sump does not need to be broken to be removed. The transfer box needs raised, and the O/S engine mount needs unbolted and the engine raised up, but it does come out
![]() 2014 Facelift Discovery |
The Britpart kit uses a Genuine LR sump pan, and ZF Lifeguard 6 fluid.
Pearls of wisdom Disco Mikey; much appreciated - is it the same for my TDV8?
Never done a TDV8 yet.
If thats the case, then ![]() 2014 Facelift Discovery |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 ![]() ![]() ![]() |
Hi,
