Home > General > Advice On TDV8 Problems - Dealer Can't/Won't Help
Page 4 of 5 <12345>
whatpothole
mrfrog wrote:
rrsboy wrote:
oh no, the big wheels invalidate the EGR valves too! Whistle Rolling with laughter
Isn't anything an excuse ? Owners' manual states only Land Rover approved accessories should be plugged into cigarette lighters. I guess a phone charger or Sat Nav power lead would invalidate your warranty unless approved by LR ?
One of the other comments the dealer made when I took the car in, was that some of the electronic problems may be caused by the fact that I've had a mobile phone charger hard wired, rather than trailing a lead from the lighter socket Rolling Eyes
So far, the EGR valves are the only thing that they've not tried to blame on the new wheels, but it's probably only a matter of time....
Post #356234 Tue Sep 11 2012 2:58pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Assuming it's fused I really can't see what the difference would be, a wire's a wire (as long as it's the correct gauge). Makes me wonder if these people are actually qualified to work on cars in the first place, or simply blinkered and behaving as they're told to even though they know better.
That's why I trust my car to an independent, at least he's got some common sense Embarassed
"Roads ? Where we're going there are no roads." Back to the future.
Post #356245 Tue Sep 11 2012 5:54pm
Bodsy
Site Sponsor
Does anyone have whatpotholes mobile number urgently?
Have PM'd and emailed, but need his number before he leaves to come up here! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #356365 Thu Sep 13 2012 6:55am
Bodsy
Site Sponsor
Contact made. Thumbs Up Bodsys Brake Bible
See it HERE
Post #356366 Thu Sep 13 2012 8:02am
whatpothole
Hi guys,
Sorry to bring this one up again, but the problems with my car have finally been sorted, after owning it for 15 months, so I thought I'd mention the cause of the anti-skid problem, just in case anyone else has it.
I ended up buying another set of genuine 20" wheels and tyres for the car, and the ant-skid problem was still present, so the dealer could no longer blame it on the 22" rims.
After numerous trips back to see them, they clearly weren't interested in doing anything further, as they could find nothing unusual in the diagnostic codes, so every time, I got the car back in the same condition. Rolling Eyes
To cut a very long story short, I eventually set up my phone on the dashboard and took a video of me driving 2 complete laps of a local roundabout, with the anti-skid running continuously until I turned off the roundabout and the steering passed back through the straight ahead position, which always fixed the problem until the next time.
Having seen the evidence, they eventually conceded that there was a problem and took the car in again for a week, after which they called me and said that they hadn't been able to recreate the problem themselves and there were still no diagnostic codes showing. Rolling Eyes
I went back to the dealership and took their senior technician out for a 15 min drive, during which I was able to get the anti-skid to activate and show him the symptoms, so he immediately said 'looks like a steering position sensor problem', which I believe was mentioned quite early on this post by one of the other guys.
Two days and one new steering sensor later, the problem has been cured, so if anyone else suffers these symptoms, hopefully this may point you in the right direction. (Just be prepared to video the problem though, as your dealer probably won't believe you!!!).
Thanks for all the original suggestions and congratulations to whoever diagnosed the problem without even seeing the car. Bow down
Cheers,
Rob
Post #391940 Fri Aug 16 2013 1:22pm
Paddi
Great write-up!
Hardly a glowing testimonial for the dealer is it?
It's this kind of follow-up report that helps to make the forum such a valuable resource so thanks for taking the time to do that. 2008 MY Java Black TDV8 HSE
Post #391945 Fri Aug 16 2013 3:14pm
simple1
Only picked up on this late on in the game.....
Had the same response from Slippery Salmon with Fullfat. Having had the 22" wheels on the Sport with no issues, seemed strange that they blamed the wheels this time. Turns out the Fullfat has torque converter issue and nothing to do with wheels...... Now have new converter and drives fine on 22's. any excuse to get out of it.
Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #391975 Fri Aug 16 2013 7:20pm
Rangster
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Ah, at last someone with the same issue when going around roundabouts or corners. Took mine to the dealer last year and they couldn't find anything wrong with it. Eventually they reset the steering angle sensor as they couldn't find anything else wrong. The problem did appear to go away or not be such an issue but I have recently asked my local Kwik Fit to check the wheel alignment again (they have already done this twice before) as I have slight wear to the outside front tyres. Although they claim the wheels are set within tolerance, I asked them to toe out as much as the tolerance will allow to try to reduce the wear. They made a marginal adjustment and since this time the issue on roundabouts has increased, so I have booked it in to the dealer next Tuesday. I will go armed with a print out of your findings so hopefully they will replace the sensor and the issue will go away for good. RRS TDV8 MY2010 Stornoway Grey
Full Exterior Autobiography Factory Upgrade
Piano Black Interior Trim inc Steering Wheel
Ivory Premium Perforated Leather
22" 5 spoke "Style 7" Diamond Turned Alloys
Towing Pack
Diesel Tuning Box
Privacy Glass
Side Steps
Best vehicle I've ever driven.
Current garage also includes;
Mercedes 320 CDI CLS
TVR Tuscan S
Post #392329 Tue Aug 20 2013 5:53pm
If you have uneven wear and the stability control kicks in on roundabouts, then that suggets your suspension alignment is totally out or soemthing is worn such that when laterally loaded it causes the alignment to be totally out.
Did Kwik Fit do a full 4 wheel alignment using something like the Pro Align system? Did they set tight tolerance mode?
I wouldn't be suprised to find your wheel alignment is wrong and that you have something like an excessively worn suspension arm bush 2012 SDV6 - it's missing a couple of cylinders
Post #392357 Wed Aug 21 2013 1:06am
Rangster
Just to update, went to the dealer who couldn't find any error codes and they checked the wheel bearing which was ok as apparantly a worn wheel bearing can cause this issue. Advised dealer that it could be steering angle sensor and they agreed to change.
When it went in for the sensor change, they checked for fault codes again and checked wheel bearing again, only to find wear in it. They changed the wheel bearing and the fault does apper to have gone or certianly much less apparant (slight wheel shake has also disappeared which I had put down to poorly balanced 22's).
Fingers crossed.
Thumbs Up RRS TDV8 MY2010 Stornoway Grey
Towing Pack
Diesel Tuning Box
Privacy Glass
Side Steps
TVR Tuscan S
Post #394582 Tue Sep 10 2013 10:17pm
Rangster
Oops, it was obviously wishful thinking when I thought the issue had gone away. DSC light is still illuminating on corners.
Spoke to dealer who has now agreed to change steering angle sensor as per an earlier conversation I had with them.
Fingers crossed changing this will definitely solve the issue. RRS TDV8 MY2010 Stornoway Grey
Towing Pack
Diesel Tuning Box
Privacy Glass
Side Steps
TVR Tuscan S
Post #394920 Fri Sep 13 2013 3:47pm
Rangster
Sorry for late response;
Kwik Fit used a Hunter HawkEye 4 wheel alignment system which was set on tight tolerance initially. The problem with the DSC existed then and this is when I experienced slight tyre wear on the outside. I re-visited Kwik Fit who set the tolerance to max toe out permitted within tolerance. The DSC problem does appear to be slightly more noticeable but the tyre wear appears less. RRS TDV8 MY2010 Stornoway Grey
Towing Pack
Diesel Tuning Box
Privacy Glass
Side Steps
TVR Tuscan S
Post #394923 Fri Sep 13 2013 4:15pm
I still think you have a wear issue somewhere. A sensor problem might cause the DSC issue but obviously not the tyre wear.
The RRS seems to consider suspension bushes to be consumable items. 2012 SDV6 - it's missing a couple of cylinders
Post #394982 Sat Sep 14 2013 7:53am
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
What was the fix with the egr valves? I've had mine for a month and it does that squeak on every shutdown. Reading on here, it may be normal but seems not everyone has the same level of noise? Cheers, Steve
Post #467544 Wed Jul 15 2015 6:22am
gogsy1956
Been reading this thread with interest,,,,, especially the whining noise when the engine is turned off,, always wondered what it was. Mine will whine for a few seconds but is only noticeable if you stand right in front of the car when outside or its in the garage,,, not noise at all 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #467547 Wed Jul 15 2015 7:54am
Page 4 of 5 <12345>
