![]() | Home > Technical > Default Audio volume |
At level 7 I can't hear mine when the car is moving... and at 20 it's VERY LOUD INDEED!! At 90mph, I have it set to 15 and move it down to 13 for town traffic.
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
Mine is just a bit too loud (particularly in the morning when my ears are sensitive! ![]() Mr LR technicians......what's you take? RRS TDV6 Bluetooth, VR, Roof ![]() |
Hmm... maybe the calibration is different for the Oz market? |
There may also be some difference between the standard system and the Premium ICE number.....amps, speakers etc. Mine is your bog standard model. RRS TDV6 Bluetooth, VR, Roof ![]() |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Something that bothers me about the volume is that if you have a DVD playing through the RSE system, or an iPod or other player connected through the AUX socket, setting the volume level at 20 sort-of equals maybe a 10 with other sources (radio and CDs), so of course you crank it up to 25-30 to hear it properly... But if the navigation lady suddently chimes in with her instructions at that volume level, she blows your eardrums away, and offsetting the nav volume level while using the DVD or AUX inputs does not "stick", either. |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
thats the downside of extended battery lives of Ipods and other portable equipment - you just sacrifice the line level voltage output. We have so many problems with our installs with Ipods - they can be a right pain!! |
Black Sea Member Since: 18 Jul 2006 Location: Black Sea coast Posts: 5 ![]() ![]() ![]() |
How can you modify the limits of 7 and 20? 2006 Range Rover Sport TDV6 SE Java Black |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
Why would you want to ? Do you really want to save volume settings of lower than 7 or higher than 20 ? |
I want to save volume settings of lower than 7. Thank you in advance. 2006 Range Rover Sport TDV6 SE Java Black |
Do you have the standard ICE or the Premium ICE ? |
