Home > In Car Electronics > Can you put a hse tv/sat nav into a s model.
Mitchmx
Hi guys. Just purchased a rrs but after driving 4hours to collect it I found out it was a s not a hse. After a long chat and a cracking deal later I bought it.
Are all sports fitted with the same wiring loom so I can buy the extras and plug the compoints in? First one is the sat nav. Has any one fitted one or can it be done? Any help would be great
Thanks in advance
Mitch
Post #351466 Sun Jul 22 2012 7:45pm
The sat nav isn't that good, to be honest. If you just wat sat nav then a TomTom or similar would probably be a better bet. A smartphone with CoPilot is also pretty good (have it on my Nexus and it works pretty well).
The sat nav in the older cars is dvd based so you'd need to buy that too. And the discs are c.£165 a time if you want to keep it up to date. 2012 SDV6 - it's missing a couple of cylinders
Post #351474 Sun Jul 22 2012 8:17pm
Mitchmx
Oh right. So is the sat nav not the tv as well?
Also I have the phone logo on the stereo but when I press it, it comes up with "phone not fitted" dose this mean my stereo is not bluetooth compatible?
Post #351510 Sun Jul 22 2012 10:35pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hello Mitchmx.
In order to complete the car with satnav and phone, You will need some new
wiringlooms, and a bluetoothmodule. The satnav consists of a screen, and a dvd-unit
(where hardware and software for nav is). The phone needs a bluetooth module, and
the triggers on the steeringvweel, right side (green and red receiver pic)
The entertainment system communicates via a most-cable, and if You should get your hands
on all the parts needed, they must be enabled with either a Faultmate or similar.
The stereo must be a high-line unit, that has the outlets/inlets for it all
(6cd changer, and the amplifier also must be compatible)
So, it will not be an easy job to upgrade the car to HSE spec, it is possible though, but a lot of effort.
There is a guy on the Disco 3 forum, (disco3.co.uk) who has done it, search there, the member there is called "Wiggs"
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #351512 Sun Jul 22 2012 10:49pm
Mitchmx
Thanks for the help. I'll try and get hold of him.
Post #351641 Tue Jul 24 2012 8:45am
