Home > Technical > Removal of Back Interior Panels?
xLusi0n
Is there a write up of how to remove the passenger side rear (trunk) interior panel? I know it's pretty straight foward but a write up showing me where the clips are and any tips would help minimize damage as I remove it.
Also what about the inteior panel of the rear door?
And lastly, removal of the passneger side rear lamp...thanks.
Post #344044 Fri May 18 2012 8:27am
MAW
Rear lamps are retained by 2 visible screws and located by 2 pins - once the screws are out pull rearwards - sometimes the pins seem like they don't want to release but they will.
Rear panels - remove the luggage fixing that side - lift the boot floor (where the tools etc are), remove the floor panel retained by the luggage fixing. Pull the rubber gasket off the edge of the panel being removed. Pull the rear panel away from the body and clips will release. Remove load cover before pulling side panel off.
From memory but should be it Smile
Post #344047 Fri May 18 2012 9:02am
xLusi0n
Thanks, I'll try it.
Post #344369 Mon May 21 2012 6:12pm
