Home > Technical > Tailgate issues - slam to close
Try1ng
Ireland 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Hi guys,
2 issues with the tail gate.
The first is the main tailgate is hard to close, need to slam it other wire it just catches and seems to move about 1/4 inch in and out.
2nd problem is with the glass opening, I thought the switch was gone as previous people have indicated but I replaced it last night and still nothing, it's looking like the loom might be at fault but just wondering if there are any other suggestions? does naybody know if there is another way to open the glass (the keys are not programmed for that and with the glass not opening so I can't programme the keys) Sad
Many thanks,
Ronan 06 RRsport HSE
Post #343715 Tue May 15 2012 2:04pm
rigsby
tailgate
Hi Try1ng, dont know if it may help but if one part of the tailgate is open (in your case the main part) then the other button (the glass button) is disabled. Could it be that as the main part is loose then your upper tailgate button is disabled. My main tailgate only needs to be shut gently and then it pulls itself in to the shut position. Maybe try pushing the tailgate shut manually and hold the pressure on it whilst trying the glass button to see if it releases. sorry but that is all i can suggest regards Rigsby. good luck MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #343735 Tue May 15 2012 5:36pm
