![]() | Home > General > Petrol in an oil burner..... help please.... |
Have always been led to believe that petrol in a diesel car isn't as catastrophic as the other way around.
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Thanks you very much Bean..... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
They say adding 2 stroke oil (at the correct specification) into the full tank of diesel will also help lube parts the petrol may have stripped |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
As I understand it, it depends on whether it is a common rail diesel or not. With these, the entire fuel system is high pressure and the fuel pump is lubricated by the fuel itself. Petrol is a solvent and doesn't lubricate like diesel does so the fuel pump can be damaged by running petrol through it. I think the injectors can suffer for the same reason but not too sure.
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
I am aware of a RRS that at 1/2 full had 30 litres of petrol put in, which then ran for 100 miles until getting low it wouldn't start. The driver after being informed of his or hers error then filled then tank with diesel and continued doing this every day for a couple of weeks. That was about 10,000 miles ago.
Apparently it will emulsify, and lube various parts it comes in to contact with, sulphur used to do this, but due to low sulphur diesel it doesn't lube as much, adding 2SO will give the diesel its lube back, I'm sure you have read this and know about it, but they say it benefits the engine and keeps it cleaner, lots and lots of people saying it helps, but non of them appear to be scientists who will actually publish their findings. http://www.freel2.com/forum/topic878.html |
chilly Member Since: 07 Dec 2010 Location: north east Posts: 192 ![]() ![]() ![]() |
not the end of the world once drained and filled up take it out for a good run and as some one mentioned throw a littl bit of 2 stroke into the full tank and take it out for a good run and just keep topping it up each day for a week or two while the 2 stokes working its self through ,
Thank you everyone..... I emailed him the thread......
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
Is it still in LR warranty?? If so i'd leave LR totally out of the loop as they'll want loads of other expensive stuff changed if he wants to keep warranty cover. |
Good thinking.... it is under warranty.... i'll advise him... Thx 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Hope he does not have a fuel burning heater |
Don't think i'll tell him about that one........ he'll be thinking .. Hmmmmm.... new car !! |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
don't go near LR with this!
