![]() | Home > Maintenance & Modifications > Which engine is best for LPG conversion - 4.4 V8 or 4.2 S/C |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
Hi, whatever you do, do not convert a 4.2 sc. Scharger not designed to use gas. i ve heard some scary expensive stories about people using it on these engines. the other engine would be fine i believe. Sorry to sound gloomy. You cant beat the power delivery of a charger. |
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Thanks for the reply! What goes wrong when you convert the s/c engine to LPG? I'm sure a 4.4 V8 will be plenty powerful enough, of course, but a s/c would be something else!! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
i think its about lubrication of the valves and the chargers cambers. they run dry and over a period of time these fail causing expensive rebuild. i'm sure someone out there could give you better advise. If your worried about fuel costs go for the 4.4. my sc gives about 15 mpg depending how i drive |
4.4 will be plenty quick enough I'm sure!
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
hello mike c
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Just buy a TDV8 and have 4.4 performance with nearly TDV6 economy. And if you want a bit more performance they map very well... 2012 SDV6 - it's missing a couple of cylinders
So basically the message is if I want power and (some) economy, go for a diesel + remap rather than a petrol + LPG?
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
in short the tdv8 at that age is worth the money and will resale much easier when and if you decide to pass it on.
What sort of mileage are they well looking sub-£20k? - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE) - BMW 330Ci M-Sport coupe - Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
Hi
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
How many miles are you getting to the 85 ltr tank (-10% for expansion iirc)? I used to get about 200 miles from my 4.4 v8 FFRR from a 95ltr tank (which took about 85ltrs to fill) |
The 85 litre tank allows me to fill approx 77 litres which gives me 210 miles approx locally, on motorways driving at around 80 - 90mph gives me 240 miles. |
