![]() | Home > Maintenance & Modifications > headlight adjust |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Have you tried the automatic calibration? Put the lights into auto mode on the switch and then put the key in and start the engine. The lights should go through a little "dance" and then set themselves to the correct level. Obviously needs to be dark enough for the auto lights to want to turn on. 2012 SDV6 - it's missing a couple of cylinders
tomma66 Member Since: 20 Aug 2011 Location: north east Posts: 33 ![]() ![]() |
now sorted thanks |
