![]() | Home > Technical > HDC Fault |
mike21 Member Since: 07 Feb 2011 Location: Essex Posts: 297 ![]() ![]() |
Should of got a warranty...................................................................
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
if you get a min, explain the humour, lost on me. op get the battery checked would be my first port of call. |
kelley07 Member Since: 22 Jun 2010 Location: wales Posts: 45 ![]() ![]() ![]() |
Thanks very much for the advise Firstinretail - Will get battery checked on Monday.
ELD70 Member Since: 20 Jan 2009 Location: UK Posts: 163 ![]() ![]() |
Get a new battery |
Update - Put battery on charge and took it to be checked at Halfords - Battery good. Put battery back on and error reading No special programs on. Took car to local garage and as i drove in - All the previous faults showed again.
glad its sorted, not cheap though |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
"should have" or "should've" If you're going to take the pi55, at least do it correctly... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Eek! You have my sympathies! At least you're back on the road now... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
