saty
| CTEK trickle charger, brand new boxed... | |
Hi all,
Selling the below as purchased in error:
Spec:
CTEK XS 0.8 General Information
Input voltage: 220-240VAC, 50-60Hz
Output voltage: 14.4V
Charging current: 0.8A
Ambient Temperature: -20 deg.C - +50 deg.C
Charger Type: Fully automatic 6-step charger for 12V batteries
Batteries: 12V lead-acid batteries (Wet, MF, AGM, Calcium/Calcium and GEL)
Battery size: 1.2-32Ah
Dimensions (L x W x H): 142x51x36 cm
Insulation : IP 65
Weight: 0.3 kg
Quick coupling - Yes
The XS 0.8 is CTEK’s smallest 12V charger. It offers state of the art technology and is perfect for charging smaller 12V batteries that can be found in motorcycles, jet skis, ATVs and lawnmowers.
The unique display allows the user to follow the entire charging process. The XS 0.8 is a compact and fully automatic 6-step charger for 12V batteries from 1.2-32Ah. The XS 0.8 is IP 65 classified (splash and dust proof), delivers 0.8A and is designed to protect vehicle electronics. It is non-sparking, reverse polarity protected and short-circuit proof. The XS 0.8 is delivered with 5-year warranty.
FULL spec here
I am selling for £30 inc postage.. Cheers
Thu Dec 29 2011 12:54pm |
