![]() | Home > Maintenance & Modifications > What battery |
DrRick Member Since: 24 Oct 2011 Location: Edinburgh Posts: 54 ![]() ![]() ![]() |
2007 TDV8 RRS with starting problems this morning. All sorts of errors that came and went . Put it on a trickle charger for a few hours and it switched on fine.
Fair enough. My only problem will be convincing the franchise branch that now 'deals' with this car that they should pay. 2.5 mths in is a bit short in my mind for a battery to die (or possibly an alternator)
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Mine is also a 2007 TDV8 and my battery died a few months after I bought mine. Batteries aren't covered by the LR approved warranty so I doubt the garage will be interested. One thing to check is that the existing battery is the correct one for the vehicle. If it isn't, then you might be able to argue with the garage with a bit more ammunition.
Currently booked into the same franchise, but Jaguar, for a diagnosis.
So, diagnosed as the alternator has given up the ghost. Currently with Stratstone Jaguar Edinburgh who have been most helpful (so far) and have the car in bits fitting a replacement.
