![]() | Home > Technical > Snow chains, 2 or 4 wheels. What's the difference?.... |
| oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148
Anyone enlighten me as to who is correct on the snow chain debate?
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644
I too am confused |
| Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586
All 4 I would say, but I'm no expert |
Thanks guys. I think all four. The car weighs nigh on two and half tons and if the rear end were to go on an icy snow covered road the fronts would do little more than act as pivot. The rear wheels are the park brake too.
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
you need to make the choice of being able to stop or being able to steer |
Exactly! I can't see how LR can say DO NOT without some justification.
| maddogsetc Member Since: 03 Sep 2011 Location: Hampshire Posts: 51
Not sure if this helps but there are threads on this on disco3.co.uk - ISTR that the chains can foul the chassis / suspension members on the rear unless you use spacers. Presume the same would be true for RRS. |
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087
Agree with statement that LR have to justify if they say fronts only. The brake balance is very much biased toward the back wheels so it would seem logical that if you didn't use the chains etc on the rears then you'd
Well, if maddogsetc information from disco3.co.uk is correct then what we have is a situation that they just won't fit not that they aren't required. That seems rather worrying....
Just to be clear, these are what I use when I say snow chains...
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162
ive used them in thick snow on all four wheels. Mind you, did have spacers on (D3), but other than that, there's no reason why you wouldn;'t want them on all four wheels.
Thank you.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
It's still confusing:
| oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359
Could it be because Landrover's Traction thingies are sold in pairs so stating they must be fitted to the front is to avoid anyone fitting a pair onto the rear wheels only. Fitting to the front wheels does allow traction, steering and braking control while on the rear the important steering control becomes nonexistent.
| All times are GMT |
