![]() | Home > Technical > Amazing decrease in fuel consumption! |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
another consideration is the winter/autumn ambient temps....ie no air con every trip and better air temp for combustion |
certainly would be interesting to see |
| JonnyDangerous Member Since: 09 Nov 2009 Location: Reading Posts: 57
OK - I've done the exact same change as the OP. Changed from 20" conti"s to 19" wintrac extremes and got the exact same result. My MPG display has changed from averaging 26mpg to now being 32mpg. I've only changed the wheels over this weekend so will report back in a couple of weeks.
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Ive noted that the fuel heater can knock around 2mpg off depending on use Mike
| All times are GMT |
