Home > Technical > replacing air suspension rear valve block
shepp
Hello
I am considering replacing my air suspension rear valve, intermittantly the left rear drops, so suspect a faulty valve.
I need to have a look at the hand brake so thought it may be worth replacing at the same time. Does any one have any info on replacing the valve block.
Any info would be greatly appreciated Thumbs Up
Post #320302 Sun Nov 06 2011 10:27pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Re: replacing air suspension rear valve block
shepp wrote:
Hello
I've done plenty valve blocks in other cars but never the rrs mate, I'd assume the unit will be a 2 way system with a valve block for the rear and one from the front. U can get pneumatic parts from most industry pneumatic shops ,
top tip for sealing the threads is Locktight thread sealant, comes in a small tube and is much better than PFE tape Thumbs Up
Post #320305 Sun Nov 06 2011 10:48pm
