![]() | Home > Technical > Bluetooth issue???? |
| nickb72 Member Since: 13 Jun 2011 Location: Wrexham Posts: 7
Hi, been reading through some posts and one recommends disconnecting the battery??
Any ideas??
| simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421
sounds like your bluetooth module isn't working, I can't remember if there is a fuse for it, but may be worthwhile to check these first. Failing that try contacting Wiggs (Member on here) who does bluetooth module upgrades. |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
Agreed,
bluetooth module should be a nokia unit connected via the fibre optic cables (MOST connection), IIRC it should be behind the left hand trim panel in the boot, might be confused as this is where it is in my FFRR, possibly the location in the sport is on the right hand side. There will be an older thread somewhere about this, try using the search on here, or possibly use Google to find the thread as this is sometimes better/faster
Thanks for the help..... |
You need to have more than 5 posts to be able to PM |
Ahh so if I message you to thank you I can move forward so
