![]() | Home > Technical > Annoying squeek from front wheel? |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738
Either a brake caliper sticking or handbrake sticking, with the rotation of the wheel it is getting hot and expanding hence why its happening after driving for a while. Well thats my guess anyway.
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
...or could be a stone or grit trapped within the braking system |
| BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 816
| RRS PIMP Member Since: 05 Nov 2008 Location: London Posts: 110
I has the same noise on mine, turned out to be faulty brake pads! I stripped and cleaned the pads 3 times, after changing them for original pads the noise stopped.
What pads did you fit? Mine were changed not so long ago so wonder if it is the same thing! |
