Home > General > Front sidelight bulbs
scott7
Scotland
Has anyone replaced the front sidelight bulbs for some that are nearer the headlight colour?.
Post #294752 Sat Apr 02 2011 7:41am
Yes i have Thumbs Up
Ady
Post #294794 Sat Apr 02 2011 4:44pm
smurf
me too.looks much better
Post #294797 Sat Apr 02 2011 4:59pm
globe195
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Any tips on how to remove the actual headlamp unit to replace the sidelight bulbs? It's fairly straight forward to remove the grill and then lift the two tabs on top of either side of each headlamp but that's where I ground to a halt. Confused I can't seem to pull the unit out as it still seems to be secured fairly tightly in and I don't want to risk any damage? Both of the tabs seem to be pulled up as far as they can go. Appreciate any help. 2006 TDV6 HSE Bonatti Grey,Side Steps,Mud Flaps,20" alloys,LED rear lights,2010 style grill,Soft steering wheel,Land Rover carpets and SS pedals
Post #294903 Sun Apr 03 2011 8:09pm
scott7
Scotland
You don't pull the tabs all the way up, if you look closely at them the holes in the tabs must line up with the pins on the headlight, push the tabs back down about 5mm and the light will come out, place a rag on the bumper to avoid scratching the paint while you pull the main connector from the back of the light, after that just unscrew the circular bulb cover and pull the sidelight bulb out.
Post #294908 Sun Apr 03 2011 8:22pm
globe195
Thanks scott7, I'll give it a go when there's some day light. Thumbs Up 2006 TDV6 HSE Bonatti Grey,Side Steps,Mud Flaps,20" alloys,LED rear lights,2010 style grill,Soft steering wheel,Land Rover carpets and SS pedals
Post #294910 Sun Apr 03 2011 8:40pm
