![]() | Home > Maintenance & Modifications > Cracked Windscreen |
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087
OEM LR Windscreen fitted at Town & County |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
While in France my screen cracked from the base to half way up on LHS; got the RRS back in UK and spoke to dealers who restate that because other systems interact with the screen and the car is still under warranty a OEM screen needs to be fitted.
| ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298
autoglass fitted an oem screen to my car....autoglass rang my insurance company to ask for permission to fit it, ...no problem though, took couple of days to get it but OEM screen fitted.
| Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495
+2
Didn't have the same luck with my insurers Direct Line who refused to cover the expense of an OEM part and only agreed to pay out £125 maximum contribution as it was MY choice not to use an "auhtorised supplier"! even though it was a Land Rover dealer.
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391
the screen that Autoglass fit is identical. The dealer lies to you, wow, big shock there.
and seriously, if you allow yourself to be fobbed off with "not OEM" should your wipers etc fail then you should be ashamed of yourself!
| Bear100 Member Since: 02 Jun 2011 Location: South Wales Posts: 106
i had my disco 3 screen replaced under warranty as the heated element wasn't working well, bit of a bummer on frosty mornings,
how did you notice it wasn't genuine? ============
it didn't have the land rover badge or any of the opticool and pv sign/symbols etc on.
that's weird, was it still a Pilkington sheet? the LR and non-LR stamped screens are identical, but I can understand being |
it did say pilkinton but none of the other ce or serial numbers that the others had.
