Home > Maintenance & Modifications > Snow foaming guide for a Foxy lady. |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 |
Thought I'd do a run through for Foxy and anyone else who may be interested.
Sat Mar 19 2011 1:00pm |
paulo_martins Member Since: 24 Feb 2011 Location: Braga-Portugal/Birmingham-Uk Posts: 55 |
Nice work. http://paulomartinsphotography.tumblr.com
Sat Mar 19 2011 1:09pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
Give your cars a good wax,then see what happens with the snow foam |
Sat Mar 19 2011 1:44pm |
V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540 |
I use the ph neutral snow foam so when ive waxed it it does'nt take the wax off. Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof. 1980 Rolls Royce,shadow 2 in white. Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's. Gone 02/52 FFRR vogue. |
Sat Mar 19 2011 2:30pm |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 |
question, when filling the snow foam bottle do you fill it with concentrated solution or do you pre mix it with water ? |
Sat Mar 19 2011 2:35pm |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
I need to replace the cheap & crappy snow foam thingie that came with the Wickes pressure washer (Lavor fitting ISTR), anyone got a good place in interwebland to buy one? Well wouldn't want a dirty pikeymobile after Guava got it so gleaming! |
Sat Mar 19 2011 2:37pm |
I usually put a couple of inch of snowfoam then top up with hot water,but if car is really bad i put a bit more foam in it. Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof. 1980 Rolls Royce,shadow 2 in white. Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's. Gone 02/52 FFRR vogue. |
Sat Mar 19 2011 2:44pm |
I cant get the snow foam to stick to mine once I've waxed it,thats what I meant |
Sat Mar 19 2011 2:49pm |
Andy, Just using the Elite own brand which came with the gun at the moment but perhaps I should try yours once I've waxed it don't want to wash that off? I diluted it 50/50 1st attempt,used it neat this week and the foam was much thicker. Need some tips now for the black plastic trim under the doors anybody recommend what they are using? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone. Audi A5 Sportback Black Edition 3.0 tdi quattro S Line |
Sat Mar 19 2011 4:20pm |
RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745 |
I've got the same snowfoam lance too. Do you just dry the car straight away? I always worry about swirl marks from not washing it properly.
Rich,I snow foamed it dry because I was told if it was wet it would just run straight off.
Sat Mar 19 2011 4:38pm |
smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81 |
DSL :- i use www.autobrite for my cleaning products
Sat Mar 19 2011 4:42pm |
I dont dry the car as the foam does'nt get all muck off,so if you dry with leather of other cloth you could end up scratching the paint work,i usually snow foam then clay then wash with dodo juice then polish with meguires then finnish off with meguires NXT 2.0 tech-wax.& 8 hours later you should have a nice shinny car. Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof. 1980 Rolls Royce,shadow 2 in white. Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's. Gone 02/52 FFRR vogue. |
Sat Mar 19 2011 7:58pm |
Thanks guys. I only got the foam lance last weekend so I wasn't sure what's best. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
Sat Mar 19 2011 9:33pm |
