Home > Technical > Number plate
rexs
Number plate
Please could anyone tell me how to remove the rear number plate. Thanks
Post #280130 Fri Nov 12 2010 9:05pm
muddywheels
Milk Float Man
All Mine have been stuck on with double sided number plate tape Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #280131 Fri Nov 12 2010 9:14pm
drdelrrs
Firmly and slooowly does it best !!
Pull firmly but slowly from top left or top right corner. When one end is clear then proceed by allowing the old plate to bend and 'peel' from bodywork.
Post #280136 Fri Nov 12 2010 9:45pm
AlexMckie
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
You could warm the plate with a hair dryer or heat gun on low setting.... Softens the glue on the foam.....
Body shops will use piano wire or a strong fishing line...
Alex
Post #280155 Sat Nov 13 2010 8:31am
KR1005
Hong Kong 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Get some fishing line and place it behind the plate and slowly cut through the back of the plate. The plate will come off without risk of breaking the it.
Post #280156 Sat Nov 13 2010 8:33am
