Home > Technical > Name that part......
Another Global Warmer
While playing with the upper tailgate switch today I realised that underneath the decorative external cover there is a steel guide bar that runs horizontal across the bottom of the tail glass. On mine there is quite a bit of rust so would like to replace asap.
Ques 1 / Does anyone have the part number and/name of this part so I can order either online or over the phone?
Ques 2 / Any ideas on rust proofing the new part to avoid it happening again?
I know galvanising would work but with it being a thin piece Im worried that the heat from the process would warp/twist the part.
Thanks in advance!
Photos to help.....
Post #277778 Tue Oct 12 2010 5:43pm
m14rsh
I am unable to help but am amazed by the rust problem.
how and what do you remove to see this?
M 2014 RRS
Post #277792 Tue Oct 12 2010 8:41pm
muddywheels
Milk Float Man
You have a 6 year anti-corrosion warranty - I would speak to LR - that is terrible Shocked
Quote:
Anti-corrosion warranty
Should any part of the bodywork of the vehicle be perforated by rust corrosion, the panels affected by the perforation will be repaired or replaced by any Land Rover dealer/Authorised Repairer, completely free of charge, regardless of any change in vehicle ownership.
The anti-corrosion warranty begins at the same time as the vehicle warranty and continues for a period of six years.
The term 'perforation' means a hole that penetrates through the bodywork caused by corrosion from the inside or underside as a result of faulty manufacture or materials.
 Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #277794 Tue Oct 12 2010 9:12pm
m14rsh
In that case I definitely wanna know what and how to take off the external panel so I can check this out! Got one year left on the corrosion warranty! 2014 RRS
Post #277797 Tue Oct 12 2010 9:57pm
Cheers guys
Will call LR this afternoon
To view/check yours, lift up the upper tailgate glass section, look at the interior plastic cover panel where the switch and lights are located, there will be approx 8 torx/star allen key screws along the length of the plastic section, once removed look at the exterior colour coded panel at the bottom of the glass, slide this upwards and remove, be greeted by the lovely photos above!
Long winded explanation to make it easy but it only takes 5mins max to do Thumbs Up
Im guessing its from the same water penetration that causes the switch issue.
Ask if any further help needed
Post #277825 Wed Oct 13 2010 12:02pm
LR might wriggle out of it due to the required paintwork inspections clauses
Nowadays you can get it serviced were you like but paintwork warranty check still have to be carried out by a LR dealer or they can void it
Post #277826 Wed Oct 13 2010 12:12pm
Havn't called them yet however I'm slightly concerned by the info on official website......
Post #277827 Wed Oct 13 2010 12:17pm
Tim in Scotland
Coming to this via a link in a more recent post but would be interested in the end result. Did you persue it through an LR dealer and get a replacement fitted? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #516377 Tue Jan 31 2017 3:24pm
His last post on here (anywhere) was 6 years ago
I suspect he has sold it and moved on
Post #516391 Tue Jan 31 2017 6:57pm
