Home > General > Overheated supercharger?
marc777
United Kingdom 2007 Range Rover Sport Supercharged Java Black
Drove down to Cornwall this morning and those that know the A38 know that there is much kick-down driving to pass caravans and ashmatic VW campers.
Sadly on arriving near our destination of Newquay, the car went into what felt like limp mode, then virtually die mode. The hapless RRS could hardly go uphill at all, and we stuttered to a 30mph crawl and eventually I had to admit defeat and pull over. The thrill of being passed by caravans etc that I passedback on the M5 while I waited for Land Rover Recovery.
Well, after 45 minutes (and having been given the once over by the local police) the recovery van arrived. Given the once over, started the car and all seemed fine.
The mechanic had no idea, and I can only think that the supercharger overheated and cut out - its happended on theMerc E55 before, Anyone else had a similar experience?
It just refused to rev over about 3000 and felt like it was on 4 cylinders. Not lumpy, just gutless.
Marc 2007 RRS Supercharged, Black & Ivory, 22" Overfinch and MY10 rear lights.
Maserati Quattroporte; OMG !!
2010 Mini Cooper convertibe
Post #273330 Sat Aug 07 2010 6:19pm
Misery
Shocked Shocked Shocked Shocked Shocked Shocked
Post #273333 Sat Aug 07 2010 8:32pm
RichardM
2010 Range Rover Sport TDV8 HSE Galway Green
Sounds like the E270 I had. That went into limp mode on the way to a stag weekend in Cornwall and wouldn't even go up a hill. Thankfully the few trips I have done down there since have been in the Alfa which has been faultless. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award
2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys
2009 TDV6 3.0 HSE Buckingham Blue - GONE
Post #273338 Sat Aug 07 2010 10:36pm
Bladerider
England 2006 Range Rover Sport Supercharged HST Java Black
Sounds like a boost leak causing it to overboost which the ecu then doesnt like.
If this was on a turbo car thats what i would guess at, or maybe a MAf or MAP going down.
J. Eat. Sleep. Race. Repeat.
Post #273343 Sun Aug 08 2010 2:33am
Bobby
It is very rare that the supercharger itself fails.
Lack of boost is usually due to the supercharger drive belt broken/slipping or there is a supercharger air intake fault or there is a major air leakage (after the supercharger). Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #273344 Sun Aug 08 2010 7:20am
avos
Usually you would be able to find codes, did they check with the right tools that can read all propriety codes from the RR?
For some SC models, the + and - where switched for the supercharger intercooler pump (found it out myself when I placed a larger capacity pump). I can also remember that I found alter a TSB, but can’t find it now so am not sure if it could affect your car. The effect is that the pump will still function, but at a much reduced capacity.
So that could explain that after a couple of high boost runs the system gets very hot.
When it is getting to hot (for a period of time) for the ECU, then a fault code should be registered, and when it happens twice (2 drive cycles) the MIL (Check engine light) should turn on. However I have never experienced this, so am not sure if the behavior of the car matches the above. RRS SDV6 HEV Dynamic
XKR 700 BHP with Twin-screw and LSD
Post #273345 Sun Aug 08 2010 7:42am
marc777
Thanks for the input. On the Merc it was the intercooler pump that would overheat and then shut down. I'll see if I can get LR to to a diagnostic. Thanks Avos 2007 RRS Supercharged, Black & Ivory, 22" Overfinch and MY10 rear lights.
Post #273346 Sun Aug 08 2010 8:10am
yep you should do this ! Thumbs Up
Post #273352 Sun Aug 08 2010 9:54am
rockportpurple
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
supercharger
hi all my supercharged has just strarted with the same fault it will go into limp mode after a few hot runs and i have turnde off the ignition left it five min and it has rectified itself,but it is booked in tomorrow as i have been told it is either thepump or the positive or negative that was misswired at the factory
i was going to attempt it myself but but i dont have the time,if anyone has a simple d.i.y fix and how to do it why not post it up
regards
clive
Post #273362 Sun Aug 08 2010 1:57pm
Bobby
LTB00041v2 concerns "Reduced Power With The Possibility Of Diagnostic Trouble Code
(DTC) P0096 and/or P2601 Stored".
4.2L V8 Supercharged Only VIN- range :5A901924-7A109767 are affected.
The cause is "the electrical harness supply and earth for the auxiliary coolant pump may be found to be cross connected in connector C3006, causing the Engine Control Module (ECM) to reduce power to prevent damage because the pump flow is low. The auxiliary coolant pump will be degraded because it has been running backwards".
Smile Malaysia Boleh!
Post #273363 Sun Aug 08 2010 2:25pm
Misery
Bobby once again as always. Bow down Bow down Bow down Bow down Bow down Bow down
Post #273372 Sun Aug 08 2010 6:57pm
Tim in Scotland
Bet there will be queues of S/C RRS owners at dealers tomorrow to get their cars checked out Mr. Green 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #273373 Sun Aug 08 2010 7:06pm
i start to think that Bobby may be 007 !!!! Shocked Laughing Wink
Post #273385 Mon Aug 09 2010 6:28am
marc777
Thanks for that. The trip certainly involved lots of +/- and so I think this may be the answer. Will report back later in the week as I am told Truro's LR dealership tends to be stacked out on a Monday dealing with holiday maker vehicles as well as the local LR population. Mr. Green
Post #273390 Mon Aug 09 2010 7:15am
Bobby
Laughing Laughing Laughing Malaysia Boleh!
Post #273392 Mon Aug 09 2010 7:22am
