![]() | Home > Technical > Camshaft sensor |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
1. What year is your tdv6? Better still, update your RRS profile.
| Trafforde Member Since: 30 Jun 2010 Location: London Posts: 12
Hi Bobby.the car is an 05 model and the codes are p0405-00 egr and p0341-00 cam sensor thes are from the autologic laptop.cheers John. |
John, you have a PM. Malaysia Boleh!
Hi Bobby.tried to send you a pm but not allowed as less than 5 posts would of been nice if it told me that before i typed it all. |
Well checked the loom back to ecu cam sensor switching ok as is the crank sensor.
Found the problem.removed front timing cover and the tensioner brng had disintegrated ,belt slipped due to slackness ,not very good for a 75.000 mile car,valves just catching by the feel of it,lets hope there ok,its amazing it drove home.Thanks to bobby for suggestions,put this one in your book mate.cheers John. |
Glad it worked out OK for you! |
Thanks,started to fit new belt and tensioner ,strugled to remove the starter motor to get to the timing hole these designers really are crazy.The cars an auto so has different pin than a manual.We have found a hole close to where the original belt was fitted about 2 teeth away,we have used this but have piston and valve clash. We may have valve damage but in the slipped position it turned over on the starter,any tips please ,it may be there are more holes,does any one know if when the pin is in the hole if no 1 piston is at top dead centre ,cheers.John. 2oo5 sport tdv6 (broken) S1 88 diesel (owned for 35 yrs) !968 Nelson 800hp ex round britain Cowes torquay race boat. |
Had a good look at the failed tensioner today,its only got a single row brng in the middle of quite a wide pulley.
The Good news is its running ok no damage,the bad news is it now shows p132bturbo boost .performance,is this dreaded turbo change because it was crap in the first place.Any help please thanks,John. 2oo5 sport tdv6 (broken)
| All times are GMT |
