You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > Tips & Tricks > Service Required message - can it be reset without a dealer?
twozzie
My 2006 is due for an interim service to change the oil etc. The stealer here in CA wants about $140 but I can get the oil changed much cheaper but of course the Service required message stays on.
Can the message be removed or reset without stealer intervention? (i could do it in my 1998 Jeep )
Thu May 27 2010 8:15pm
acowx
Re: Service Required message - can it be reset without a dea
Seemingly it can be reset via the dash controls on some vehicles, not on my 2006 RRS SC.
I bought a simple reset tool from BlackBoxSolutions for roughly 100 sheets ($)
Link is below under "Blackbox Basic Bits", model is BCSRT (Service Reset Tool) :-
The procedures described below are relevant to the following European specification models:
Model Chassis Model year
Discovery 3 / LR3 L319 2005 to 2006
Range Rover L322 2002 to 2004
Range Rover Sport (not supercharged) L320 2005 to 2006
1) Procedure to check/reset service status – Distance counter
Switch ignition OFF
Press and Hold left instrument panel reset button, switch ignition ON to position ‘I’ (accessories)
Keep reset button pressed for approximately 5 seconds until the LCD displays ‘RESET SIA’. The
distance to service (e.g. 2150 miles) and the service type (e.g. Inspection/oil service) will be
displayed.
Has the ‘Reset Distance’ limit been reached or exceeded?
o NO - Follow instructions in section 2 below
o YES - Follow ‘Reset Distance Counter’ instructions below
Reset Distance counter procedure
Press and hold left instrument reset button for 5 seconds. ‘RESET’ will begin to flash on the LCD
display.
To reset distance the left hand button should be pressed before the ‘RESET’ message has flashed 5
times
The LCD will display ‘END SIA’. Switch ignition off
2) Procedure to check/reset service status – Date counter
Press left instrument panel reset button once
The LCD will display ‘RESET SIA’ followed by the service due date.
Has the ‘Reset Date limit been reached or exceeded?
o NO – Press the left instrument button once. The LCD will display ‘END SIA’ to indicate the
service interval check/reset procedure has been cancelled.
o YES - Follow ‘Reset Date Counter’ instructions below
Reset Date counter procedure
display.
times
