Home > General > Rear door off-side seal torn
Valjean
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi - I have had my RRS for 2months and noticed that on the weekend that the passenger door seal on the drivers side has torn - is this covered by warranty? I am taking it to the dealer tomorrow.
has anyone else had this happen?
Will post photo when I learn how CURRENT: 3.0TDV6 HSE Stornoway Grey, Privacy Glass, Rear DVDs, Extended Leather
Post #266580 Wed May 19 2010 5:18pm
SingeRRS
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Exactly the same problem on a Sept delivered MY10 - rear near-side door seal split. I was told it hadn't been installed quite right and it was replaced under warranty.
Singe
Post #266587 Wed May 19 2010 5:32pm
Endjin
Scotland
I would imagine it will be covered by warranty. Interestingly, I took delivery of my new RRS in early Jan during
the really cold weather and my dealer made a point of putting some lubricant on all the door seals
to stop them freezing & tearing. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #266590 Wed May 19 2010 7:11pm
Valjean
Thanks.
Will see what Stratstones say tomorrow!! CURRENT: 3.0TDV6 HSE Stornoway Grey, Privacy Glass, Rear DVDs, Extended Leather
Post #266593 Wed May 19 2010 7:55pm
Valjean
Dealer confirmed that a new door seal is required. Waited 30mins to be seen, 30seconds later confirmation of the split, dealer will order a new one and ring me to fit. Said it would take 10mins to fit.
Funny, having owned many cars over the last 20year, from fiats to bmws, never had a door seal go before - on inpsection they are quite thin compared to other cars.
I've only just replaced the door seal on my VW Camper 1976!!
LR need to make sure they don't reduce costs too much at the detriment of quality. CURRENT: 3.0TDV6 HSE Stornoway Grey, Privacy Glass, Rear DVDs, Extended Leather
Post #267080 Mon May 24 2010 9:22pm
HappyHammer
United Kingdom 2011 Range Rover Sport Supercharged Sumatra Black
Hi guys,
I need to replace the door seal on the passenger side behind the driver. It seems to run through a plastic plate of some sort at the foot of the door - SEE PIC.
Can this be easily removed and replaced?
Sadly the pic has loaded incorrectly. If you turn 90 degrees to the right you get the correct image. RRS 2011. 5L, S/c in Sumatra Black. She's lurvely.
Post #526138 Mon May 15 2017 9:29pm
It is easy enough to remove, it just pull up but it might be advisable to get a couple of spare clips as sometimes they disappear down inside the bodywork or they can distort. especially if they have possibly been removed before.
Clip IPN500090 about 50p each.
Post #526147 Tue May 16 2017 3:41am
HappyHammer
Thanks Col RRS 2011. 5L, S/c in Sumatra Black. She's lurvely.
Post #526264 Wed May 17 2017 5:59pm
