Home > Technical > TDV8 Exhaust Gasket |
BAWSACK Member Since: 12 Jan 2010 Location: Falkirk Posts: 18 |
Holy smoke Richard! glad it was still under warranty for you. I have read this somewhere before about removing the body to gain access to the turbos etc, it would fear you having to pay to get this done!
Thu May 06 2010 9:51am |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Holy Moly That does seem rather an extreme situation just to replace a gasket! Glad you are not out of pocket on this. Pics would be really interesting 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Thu May 06 2010 10:17am |
rasspe Member Since: 04 May 2010 Location: Midlands Posts: 9 |
If you send me your email I will send them not sure how to put them on here
Thu May 06 2010 10:31am |
Sorted gallery.
Thu May 06 2010 2:08pm |
NightFox Member Since: 02 Mar 2010 Location: North Shropshire Posts: 381 |
Jeeeeeeeez! Not a DIY job then! Alfa Romeo Giulietta 1.8::MG Montego Turbo::MGB GT::Rover Sterling::MGF::MG ZT 190+ Discovery Series II Td5 GS::Discovery 3 TDV6 S::Freelander 2 TD4 XS::Freelander 2 TD4 SE Range Rover Sport TDV6 3.0 |
Thu May 06 2010 4:40pm |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 |
Can't find a Technical Bulletin but there is a Service Bulletin listed on GTR. Title is - Range Rover Sport 3.6 TDV8 Exhaust Manifold Reference: SSM44148 (1) Bobby Can you reveal the contents please. |
Fri May 07 2010 8:56am |
Will ask the dealership when I collect it back hopefully today
Fri May 07 2010 10:58am |
Well guess what the dealership phoned today to say both heads are coming off and being sent to a machine shop to be drilled out and retaped.
Sat May 08 2010 7:34am |
klm Member Since: 30 May 2006 Location: UK Posts: 155 |
well chuffed,,,,,,,,,,,,, just been informed that mine has now got to have this done |
Thu May 27 2010 5:31pm |
Sizzle TDV8 Member Since: 22 Mar 2010 Location: London Posts: 117 |
Sorry for being stooopid..... But what's the problem with the gaskets??? Are they just a inferior material prone to failing or what???
Fri May 28 2010 11:45pm |
It's not the gaskets, it's distorsion of the exhaust manifolds. - see below.
Sat May 29 2010 10:18am |
Thanks for the info Bob.
Sun May 30 2010 10:33am |
This is one problem I haven't noticed - yet! From exhaust leaks I have heard in the past I would expect that if you open the bonnet and hear a hissing/whistling noise while the engine is running at constant speed you may have an issue.
Sun May 30 2010 11:36am |
Hi Guys
Thu Jun 03 2010 7:54am |
