![]() | Home > Technical > RRS Headlight Component??? |
| Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275
Looking at the handbook the zenon bulb just seems to be held into the headlamp by a bent wire spring clip hinged on the headlamp. If it is a halogen bulb it is held in by an unattached pressed steel spring plate that isn't available from LR if you lose it - as someone downunder found out. |
| Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835
MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Did you manage to get one in the end Zilch? |
Bob no, but at this moment one gentleman from D3 site (TLO), i believe he is a parts managers from LR in Yeovil is looking through some of the breakers for me.. also one parts manager in OZ is also looking through any warranty returns.. Its a joke that you cannot get some thing simple as a Bulb retaining clip without the need to spend hundreds of dollars on a replacement unit..
Glad to hear you managed a temporary fix. |
| All times are GMT |
