Home > Technical > Radio Issue |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2834 |
Symptons ; listening to the same old dross on the radio and before you can switch over all goes quiet and it sounds like its coming out of only 1 speaker at about a 3rd of the volume it should be, very tinny
Fri Jul 24 2009 9:55am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
How long has this been hapening Zilchy?
Sat Jul 25 2009 3:06am |
BKHK, the problem was originally reported within the warranty period, and i am treating it as not fixed yet (it took nearly 2 months to get the new radio from the UK), its 3 trips and 6 months so far, so i will leave it to the dealer to argue the toss with LR about who pays. That said i took out the 3 year extended warranty with Allianz in March, so i can always let them go into battle to recover, if it is the loom routing, that was an issue at manufacture stage, so i would say there is a good case to recover costs against LR. Are you coming up in Sept for the LR expo, a few members on here are going, need a few more brits to even the nationality out Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Sun Jul 26 2009 1:05am |
Vehicle came back tonight after 2 days, down to the wiring loom which is normally routed through a channel in the cabin floor, it had managed to extract it self from the channel during manufacturing and become gently crushed by the movement of the drivers seat over a period of time, the Dealership is pretty sure this has been the cause of all the Radio volume problems.
Tue Aug 18 2009 10:09am |
