Home > General > Range Rover Sport *STEREO Problem* (Low Power Mode)
Page 1 of 3 123>
amd2005leasing
Germany 2006 Range Rover Sport TDV6 HSE Java Black
I have at my Range Rover Sport Built: 2006 is a problem!
Max volume is 35 IS NORMAL!
When I turn on and the vehicle can I drive after about 5 min.
ONLY Maximum 20 According rotate!
COME AS A MESSAGE:
*** *** LOW POWER MODE
I'm desperate! What should we do??
Appendix: harman / kardon system (original)
Post #222205 Tue Apr 14 2009 8:38am
The low power mode message is what you get when you leave the stereo running on the battery alone.
In mine, volume 20 was plenty loud enough.... I can't imagine 35 even being feasible to listen to Confused
Maybe you have issues with your battery?
Post #222209 Tue Apr 14 2009 8:48am
Bobby
check battery.. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #222229 Tue Apr 14 2009 9:55am
amd2005leasing
the battery is okay !!!
Post #222232 Tue Apr 14 2009 10:11am
Leo
Kenya
How did you check the battery? This is one of the signs that the battery is on its way out. Thumbs Up
Post #222234 Tue Apr 14 2009 10:26am
amd2005leasing
If i start to drive the car, the music goes to 35 max. loud.
And then after about 5 min. I can only max. 20 According to rotate. and then, *** LOW POWER MODE ***
PLS HELP
Post #222240 Tue Apr 14 2009 11:29am
So, let's try to understand what Google Translate is telling us Wink
When you start the car with the radio turned on, the volume automatically increases to 35 and then after 5 minutes drops to 20 and you can turn it no higher even if you wanted to?
If you're convinced the battery is OK, then it sounds like a trip to the dealer.
Post #222241 Tue Apr 14 2009 11:32am
anthony-apl
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
i think you need to turn up your hearing aid Thumbs Up 16 model year yulong white autobiography
Bentley continental GTC
2011 VW Transporter T5 Kombi 140BHP with sport line kit for work
15 model year black RRS HSE gone
11MY Fuji White 3.0 TDV6 HSE
Ivory premium leather
Ebony contrast stitching
Extended leather pack
Anigra Wood now gone
08MY Range Rover Sport TDV6 GONE
Post #222242 Tue Apr 14 2009 11:33am
amd2005leasing
Normally when the car is only when the engine is running at max. 35 make loud!
But after 5 minutes, I can only max. According to 20.
Normally i can make only 20, according to only when the engine is not running!
Post #222243 Tue Apr 14 2009 11:39am
It really has to be the battery or alternator - it's the only time the radio switches to low power mode. 2005 Zambezi TDV6 - Gone but not forgotten
Post #222244 Tue Apr 14 2009 11:45am
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Maybe Angel can speak in German to him... and translate properly... Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #222248 Tue Apr 14 2009 12:52pm
Es ist nicht nötig Ich spreche ausgezeichnet Deutsch! 2005 Zambezi TDV6 - Gone but not forgotten
Post #222249 Tue Apr 14 2009 12:55pm
Jimmy_75000
Et je parle un excellent francais aussi ! Whistle Range Rover Vogue ‘17 TDV6
Post #222254 Tue Apr 14 2009 1:32pm
amd2005leasing
Also bei Range Rover Sport kann man ja nur wenn der Motor läuft auf max. 35 Drehen !!!
Wenn der Motor nicht läuft und man will die musik lauter drehen geht das nur bis 20 !! OK NORMAL !!
Aber ich starte das Auto und die Musik geht bis 35 und danach nach ca. 5 min geht nur max. 20 (LOW POWER MODE)
DANKE FÜR HILFE
Post #222257 Tue Apr 14 2009 1:50pm
Wahrscheinlich, weil man Akku wird leer. 2005 Zambezi TDV6 - Gone but not forgotten
Post #222258 Tue Apr 14 2009 2:11pm
Page 1 of 3 123>
