Home > Technical > Using the Snow/Ice setting on the jog dial?
Red1903
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
On the way home from work today I hit some awful driving conditions on a quiet country road. The road was covered in fresh deep snow lying on top of ice, as i approached a gentle hill section of the road I decided to try out the snow/ice setting using the jog dial in the centre console. Car was doing around 20mph when I selected the setting, the car kept slowing until it was more or less at a crawling pace with 1500 rpm showing on the clock. The car was making so little progress I changed back to the default road setting where good progress resumed.
Is this normal?
Post #210277 Fri Feb 06 2009 10:00pm
Doing 20mph on icy roads as described is too fast. 2005 Zambezi TDV6 - Gone but not forgotten
Post #210278 Fri Feb 06 2009 10:37pm
MAW
I have been testing these settings also - takes some adjusting to - power responses are all adjusted and i have found that when you switch between modes it doesn't always immediately 'update' ie snow peformance in on road mode.....
Post #210281 Fri Feb 06 2009 11:07pm
Tim in Scotland
20mph on ice Shocked Shocked 2.6tonnes doing 20mph on ice, doesn't bear thinking about the amount of damage it would do before coming to a stop. Anybody would think you are trying to get a new car out of the insurance payout! Whistle Whistle 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #210286 Fri Feb 06 2009 11:19pm
Josh
If you want to drive faster in the snow/ice setting, then all you have to do is apply pressure to the accelerator pedal and it all works as normal. With the exception that it will move off from standstill in second gear for better traction.
But why would you want to Shocked TDV6 - gone
TDV8 - gone
Post #210293 Sat Feb 07 2009 12:18am
Jonnylp
Is it perfectly safe to apply the 'snow' setting whilst driving ? Or do you need to bring the vehicle to a standstill first ?
Post #210294 Sat Feb 07 2009 12:49am
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
I have been using this extensively this week and TBH - hats off to Land Rover, pure genius Thumbs Up
You can actually feel the grip - sad I know, but I have nicknamed it "panther setting" Whistle Whistle
Simply gives you surety at times of crisis, I absolutely love it. I have used whilst moving at 40-50 mph, just for extra grip in slippery conditions. Used it all the way to work this morning and was doing 60 most of the way, roads were almost clear with just a few icy patches on the outside lane - it still gave me the confidence, just in case.
In the thick stuff, 10 mph max - even with all the gadgetery - its not you, its the muppets in their 2 wheel drives causing chaos. Rolling Eyes
Used it on the FL2 tonight - equally impressive. Thumbs Up L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #210297 Sat Feb 07 2009 1:02am
Red1903
Seems to be a problem for the car if the Snow/ice setting is selected when the car is already moving while in normal mode?
Tried the Snow/ice setting from stand still and the result was impressive, car pulled away no problem in over a foot of snow and was extremely sure footed, the winter tyres do make a huge difference to the RRS.
Forecast is for lots of snow overnight and plan to take the RRS to higher grounds to give it a proper workout and see just how capable this car is....... so far top marks Thumbs Up
Post #210298 Sat Feb 07 2009 1:07am
not alone I hope - remember the RRS isn't invincible - don't get stuck Thumbs Up
Post #210299 Sat Feb 07 2009 1:08am
Jonnylp
Good luck !! Make sure you get some pictures !!
Post #210300 Sat Feb 07 2009 1:16am
Red1903
Gents, click on the link and select picture number 2 from the article this will give you some idea of the conditions we can expect tomorrow. Mates taking his defender along in case I get stuck Rolling Eyes
http://www.timesonline.co.uk/tol/news/weather/article5679646.ece
Post #210302 Sat Feb 07 2009 1:20am
Post #210317 Sat Feb 07 2009 9:52am
DiscoStu
It's designed to be used on the move Thumbs Up
There's a good thread here about the Grass/Gravel/Snow terrain respnse mode on the Discovery A D3 not in drag....
http://www.youtube.com/watch?v=GEr9N6EGFNg...Sv8zqkav9F
Post #210318 Sat Feb 07 2009 10:02am
swiss
Switzerland 2008 Range Rover Sport TDV8 HSE Java Black
Having just been in the mountains training with Range Rover........
The dial can be moved at any time on the move. If you use the snow setting you need to put more pressure on the accelerator to maintain the same speed. I was driving at 60mph with ease on snow and ice - no problems. One thing though. Keep it in high gear. Low settings put too much torque to the wheels - see next point!
If you want to have fun and start drifting, change the dial to sand. Kicks the arse out nicely. Smile
One new thing I did learn was that HDC works in reverse and neutral. Threw the car up a very ice covered slope and when it won't go any further just knock it into neutral and no pedals. It brings itself back down the slope with HDC engaged.
Also did some braking and collision avoidance at speeds up to 100kmh. The RRS remains under control at all times (as long as all the electronics are switched on). Impressive. Although the Defender was quite scary!
Edit: Obviously I was on winter tyres being Switzerland! TDV8 with optional dog.
Post #210324 Sat Feb 07 2009 10:43am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Off the top of my head would say that netural has to be engaged when changing to snow setting on the move, as it engages low range, HDC and off road height, all things that require you to engage netural if on the move, otherwise nothing happens.
Post #210332 Sat Feb 07 2009 11:04am
