Home > Technical > gear shift lever
800ball
Ireland 2007 Range Rover Sport TDV6 HSE Java Black
gear shift lever
Bow down please help
i recently purchased an rrs ipod integration kit and i started to fit it,as per instrutions it said pull off gear knob so i tryed while car was in park,it wasn,t happening,so i pulled harder and it came off.. BUT the plastic shaft from the gear knob down through the gear lever broke in half. half still on knob other half in lever, i can still drive but the trigger on the knob does not work. DOES anyone know how to get the other half out and is it a big job to remove gear lever to get the other half of the plastic shaft???????????[/u]
Post #209298 Sat Jan 31 2009 2:36pm
Tim in Scotland
Isn't the press button there to activate the safety interlock that stops you accidentally going straight from R to D or the other way ........ I think you may be looking at a visit to the dealer to have your gearbox electronics looked at. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #209303 Sat Jan 31 2009 3:19pm
800ball
hi tim,there is nothing wrong with the electronics but yes i can go from d to r and visa versa no problem, the shaft is connected to the button mechanically but you may be right a bout the dealer Big Cry
Post #209306 Sat Jan 31 2009 3:43pm
