Home > Maintenance & Modifications > Installing Roof Rails |
I want to put the roof rails on my new RRS - part number VUB502130
Sun Jan 25 2009 1:42pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Do they not unscrew? RRS TDV6 Gone but still around
Sun Jan 25 2009 1:48pm |
VA the intructions are on the LR GTR website IIRC. - don't do it - the dark rails won't look right on the white car.......
Sun Jan 25 2009 7:39pm |
Tim - have that but it's the hole covers that I need to know about. 2005 Zambezi TDV6 - Gone but not forgotten
Sun Jan 25 2009 7:58pm |
Looks like a phone call to CHPR's parts dept in the morning VA 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Jan 25 2009 8:14pm |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
That was some funny advice...imagine what it will look like then with a white expedition rack! Seriously though...back to the original question, assuming that the aluminum strips with the cross hairs on them is what you are trying to remove, they do pop off, they have clips every so often along the length of the strip, gently pry up starting at either the front or back of the car, and slowly and gently nudge upwards so you don't bend the aluminum. The screws to anchor the roof rails should be right under those cross hairs. If you need any help...be glad to pop over on the next BA flight...1st class ticket would be appreciated! PJPR Cairns Blue HSE 180k Miles of Adventure |
Mon Jan 26 2009 2:51am |
PJPR01 - thanks, I was hoping that you could just remove the hole covers without taking the whole rail off. 2005 Zambezi TDV6 - Gone but not forgotten
Mon Jan 26 2009 8:24am |
Is there perhaps a small rubber plug right where the cross hairs are on the new model, or just the metal strip? If only a metal strip, then I would recommend taking off the aluminum strips for drilling that hole out.
Mon Jan 26 2009 6:33pm |
OK sorted - FYI the plastic covers plug into the bolt hole for the fixing bolt. These plastic plugs are very very difficult to remove and you will damage the plugs. All sorted now. 2005 Zambezi TDV6 - Gone but not forgotten
Mon Jan 26 2009 8:36pm |
PJPR
Tue Jan 27 2009 1:44am |
