Home > Technical > ACC Issues
Killerbob
Switzerland 2009 Range Rover Sport TDV8 HSE Java Black
ACC Issues
Hi,
I have the ACC installed, and I am really happy with it, especially when driving on the motor-way. It is a great safety item, and actually I find myself using it even on the country-roads.
Today though I was driving down to Chur in a bit of a snow-fall, and suddenly I get the "Driver Intervene" message, and then the "ACC Sensor Blocked". Obviously I had a snow build-up on the sensor, but it wasn't just the ACC that didn't work, it was also the normal cruise control that didn't work. At the next rest stop I pulled over and cleaned it up, and then all was back to normal. However, this leads me to the question;
Is there a way to go on using the normal cruise control, even if the ACC sensor is not working? I.e. is it possible to disable the ACC, and continue using normal cruise control?
KB RRS TDV8, black with ivory.
Post #207192 Tue Jan 20 2009 10:27pm
PauloAmore
Scotland
Nope.
Would be nice though. 2022 P440e AB
Post #207202 Tue Jan 20 2009 11:20pm
A bit of an omission on LR's part really.
Post #207257 Wed Jan 21 2009 10:58am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
There is a way to switch off ACC I have managed to do it by accident twice ... but I can't remember what the button presses were Big Cry
The SWMBO had the same issues with it (sensor blocking) going through the Highlands of Scotland last year in winter. Sons of dogs come hither and get flesh
Clan Cameron
Post #207264 Wed Jan 21 2009 11:42am
Killerbob
It is quite annoying these days, as we are having snowfall like crazy. I need a solution, and fast. In lack of a way to turn it off, and my stealer also says he doesn't know how to, is there an ingenious way to prevent, or at least slow down, the build-up?
Post #207343 Wed Jan 21 2009 6:57pm
Tim in Scotland
Far more important than ACC dropping out in snow, is, in my view, the alarming rate at which snow builds up on the headlight lens and doesn't melt fast enough - I was surprised how little heat is given off by the HID lamps, but getting out every 2-3miles to clear off snow that isn't melting and reducing the headlamp output to nil in a snow storm isn't my idea of fun. Last winter and again in the snow we have had here in the last 3 days when driving at night this is quite dangerous.
A way of switching the ACC back to ordinary cruise would be very useful, because there are times when I like to drive in cruise mode but acc isn't sensible
I wonder if doing something to the forward alert button does something to disengage it? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #207345 Wed Jan 21 2009 7:02pm
flydive
Move to Lugano Mr. Green Wink '08 RRS TDV8
Post #207390 Wed Jan 21 2009 10:22pm
Killerbob
OK, so there is not much to do about it, it seems.
Then onto related question;
How do I get the annoying message of the top part of the info display? It takes out the whole top half and prevents me from seeing tempts, the time, etc.
Post #208127 Sat Jan 24 2009 9:27am
Bobby
KB
Not sure about this...
What happens when you press the forward alert switch located on the dash (next to the master switches)?
What does it do? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #208136 Sat Jan 24 2009 10:46am
Killerbob
I think you mean the button under the monitor? If so, in the situation where the sensor is blocked, it switches off.
Post #208177 Sat Jan 24 2009 2:37pm
Tim in Scotland
Do you know anybody who has a stock of aircraft de-icer KB? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #208185 Sat Jan 24 2009 3:03pm
