Home > Technical > hi from newbie and a few questions please!
V8MBO
Scotland 2005 Range Rover Sport TDV6 HSE Java Black
Hi All
I have just bought a 2005 / 30k miles rr sport and it has a a few wee faults, i was wondering if anyone new if they were common faults and therefore a quick fix before it goes back to the dealer?
1/ the gear knob (auto 2.7 v6) seems loose
2/ the electric mirrors dont work
3/ the electric memory seats dont work
your thoughts are most welcome
cheers RG
Post #201872 Fri Dec 26 2008 10:39am
Josh
I'm afraid the chances are that it will need a dealers spanner to fix that lot I'm afraid TDV6 - gone
TDV8 - gone
Post #201875 Fri Dec 26 2008 11:40am
V8MBO
fuse perhaps
Thanks,
I was thinking it might be a fuse as the mirrors and the seats may be linked via the memory function?
I am not picking the car up until i get home anyway in a few weeks so it will doubtless be fixed by then,
i have a 2004 shogun i can use if its not ready as the porker wont be out to play till the spring Smile
cheers RG
Post #201882 Fri Dec 26 2008 12:45pm
Did you buy this from a main dealer? They haven't done much of a pre-sale inspection if so... Confused
Post #202228 Mon Dec 29 2008 11:42am
V8MBO
Its not as bad as it seems!!
The car had just been traded in and had not been prepared, but as i was going offshore they gave me it for 2 days to play with!
when i get home it will be all serviced and as good as new Thumbs Up
Post #202246 Mon Dec 29 2008 12:19pm
Fair enough - congrats on the new toy anyhow Thumbs Up
Post #202247 Mon Dec 29 2008 12:22pm
richh
hi guys , thee has been one case of this at our garage, it turned out to be bad wiring in the drivers door, which was blowing the fuse for both the seats and the mirrors ( i think they would only work down and in because the bcm uses the earth path to use these directions.) the lver has two small plastic thingys(technical term!) which snap- new one required, they justv pull off and push on, with a firm hand. hope this helps, Richh they all do that!
Post #211791 Sun Feb 15 2009 1:18pm
