Home > Technical > nearly every day i need to jump it off, battery problem ?
SMOGMONSTER
nearly every day im having to jump off my 05 RRS, is this a common fault or something as simple as replacing the battery ?
Post #197401 Tue Nov 25 2008 2:15pm
Jimmy_75000
France 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
well, consider that a battery life is about 2-4 years...maybe it is time to change it....Also, the cold weather might have an impact on a weak battery Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #197415 Tue Nov 25 2008 2:46pm
I would say it's time for a new battery - not sure if this is covered by warranty if under 3 years old. 2005 Zambezi TDV6 - Gone but not forgotten
Post #197420 Tue Nov 25 2008 3:30pm
RonnieG
Yep ours is the same. the Sport is my wifes who is 8 months pregnant so it now only gets driven occasionally, on the cold mornings even after heating the diesel it will turn over about 5-6 times before starting and starts on all cylinders so its not a dodgy glow plug. new battery time. TBH I sometimes think getting your own battery is better as the factory items are not always the best quality.
Post #197789 Fri Nov 28 2008 11:03am
Vogue
if its in warranty you should get a new battery from your main agent - I did and I also know several others that have also done so
Post #197795 Fri Nov 28 2008 11:29am
PauloAmore
Scotland
It was warranty item. At least mine was replaced as the lower power in the mornings (after a cold night) was causing HDC faults etc. 2022 P440e AB
Post #197800 Fri Nov 28 2008 12:31pm
MAW
My last RRS had 2 replacements under warranty - if the warranty covers it you may as well have dealer provide and fit rather than shelling out your own £.
Concerning thing is my new 58 RRS has struggled a few mornings this week and it still hasn't dropped below freezing yet...
Confused
Post #197910 Sat Nov 29 2008 10:20am
RonnieG
Just a thought... are you guys heating it in the morning.. ie turning on the ignition until the lights on the dash come on letting it sit there until the yellow "pig tail" light goes out then starting it..
the glow plugs and diesel in the pre combustion chamber needs to be heated before starting when it is cold or it has been a cold night... this will "kill" a good battert but also damage the glowplugs over time too...
heating is usually only 10 seconds and only on the first start of the day.
Post #197955 Sun Nov 30 2008 2:45am
MAW
Not sure I am waiting 10 secs but waiting - some days it is like you haven't turned the key the battery seems to struggle that much Confused
Post #197962 Sun Nov 30 2008 11:23am
Murdered out
United States 2008 Range Rover Sport 4.4 V8 HSE Java Black
I just replaced mine with one of these beasts, 2250 amps, compared to the stock 500amps (i think) Talk about power, this bad boy can power my home for a week.
http://www.kinetikaudio.com/hc2000.asp
Post #198537 Fri Dec 05 2008 6:40am
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Doubt it, its only 102Ah so only slightly bigger than the 95Ah stock batt.... If it can produce 2250A then thats great...if you need to pull 2250A, which in theory it could do for all of 2.7 minutes, which of course it couldn't as all your stock car cables would melt and/or fuses would blow. Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #198555 Fri Dec 05 2008 10:09am
Murdered out
I wasnt really being serrious about powering my home... sarcasm.
And yes, I do use about 1800amps.
Post #198667 Fri Dec 05 2008 6:28pm
rrspoland
Poland 2006 Range Rover Sport Supercharged Rimini Red
before I bought mine it was held at a showroom for few months. When I finally got the car after about a month I have noticed that hte car goes into a low power mode or it switches off the HDC mode and DSC and few other strange things. So I checked the battery and the cells were half empty. I filled the battery with the battery liquid (I do not know the english name, but you easily get it at a petrol station) a bit more than 3/4 litre and the problem dissapeard. worked for me and I didn't need to replace the battery. My name: Patryk
RRS 4.2 s/c Rimini Red
Post #198911 Mon Dec 08 2008 11:19pm
